Thanks, that does look very relevant. May have to edit the scans a
bit! Do you have original source please?
pages 166/167 and 174/175 of RCA PTA-400 "Power Transistor
Applications", '83. This was chosen because of it's references to
temperature and biasing, in the latter pages.
You will find similar references in
GE "Transistor Manual" 5th Ed, '60.
RCA SC-14 "Transistor Thyristor & Diode Manual", '69.
GE Electronic Data Library 400-6 "Transistors-Diodes", '82.
In fact, it shows up in most standard texts since the mid 60's,
including the more recent AofE (in ch2).
BTW, is this configuration related in any way to to the Sziklai Pair?
'Sziklai Pair' would refer only to the configuration of the two
transistors Q4 and Q6 in your drawing, also known as a complementary
darlington pair or complementary feedback pair.
The quasi-complimentary output refers to the combination of
darlington and complementary darlington structures used in the entire
totem-pole. It becomes fully complementary when complementary
darlingtons are used for both.
As to the term 'Sziklai' - I am unaware of it's use prior to 1980. I
assume it refers to the work of G.C.Sziklai at RCA. I have only read
anecdotal references to this man's work, but doubt he personally
called this anything other than a 'compementary' configuration. I note
his recent passing.
RL
