I'm toying with designing a device for measuring inductor saturation currents. There's plenty of these on the web, but I have a need to go up to 30A and (at lower currents) up to 1H or thereabouts.
At moderate currents and inductances, there's not a lot of problems dissipating the energy stored in the inductor, but as currents and inductance rises you have to concern yourself with peak currents for resistors and/or the total energy dissipated.
As an example, at 30A and with an inductance of 44mH, I hit the limit for a 50W 1Ω resistor of the type I have chosen (20J).
A simplified circuit is shown below:
The idea here is that at a current of around 7A the transistor begins to shunt some current around the resistors.
I've chosen a TIP35 which has a peak collector current of 50A (for 5ms) and a continuous collector current of 25A.
I have 2 concerns.
Another alternative is to trigger a beefy SCR from the resistors...
I have 2 concerns.
- Firstly, the turn on time is 1uS which will cause a high initial peak base current. Would a small capacitor across R1 help? Would it be necessary.
- Clearly secondary breakdown is an issue, which would possibly limit the current to 20A, although I could parallel 2 transistors with small emitter resistors (say 10mΩ) to increase this to 30A.
