Disposable camera flash
  • Thread starter Dirk Bruere at NeoPax
  • Start date
D
Don Klipstein
Anyone know the peak power flowing in the xenon?
A somewhat common "disposable camera" flash arrangement has a xenon
flashtube with impedance characteristic (Ko) of about 11-12 ohms-amps^.5.
I take this to mean resistance of 1 ohm at 121-144 volts, and .5 ohm at
242-288 volts.
The energy storage capacitor is typically charged to 300-330 volts. I
have a bit of experience suggesting that its impedance is a tenth or two
of an ohm, and that this flashlamp's arc at that voltage can take 50
microseconds or more to "get nice and warmed up and cooking" with the
available voltage and energy storage capacitor.
This makes me think that the flashlamp's current peaks with voltage
across it maybe around 225-250 volts with its resistance around .6-.7 ohm,
which means peak current around 300-400 amps. I would like to say closer
to 300 or low-300's than 400, after considering effects of resistance and
inductance of wiring from the energy storage capacitor to the flashlamp.
I do remember some bit of some rule of thumb that peak current through
the flashlamp in smaller camera flash units is close to initial energy
storage capacitor voltage divided by 1 ohm.
300 to "low-300's" amps times 225-250 volts means peak power around 67
to 83 kilowatts - though I would like to say anywhere from 55 to 100
kilowatts with some significant possibility of going outside this range.
This applies more when the flashlamp is is a compact linear one like the
ones used in most "disposable camera" flash units, as well as when the
flashlamp is the small most-popular U-shaped one used in many cheap
"party strobes".
I have a few web pages touching onto this:
http://members.misty.com/~don/samflash.html (mostly by Sam Goldwasser)
http://members.misty.com/~don/xea.html
http://members.misty.com/~don/xeguide.html
http://members.misty.com/~don/xesafe.html (at least look at the modified
photo of myself, the only photo of myself in my entire website now -
please know the safety info here and in the above samflash.html,
xenon strobes involve high voltage and possible other hazards.)
http://members.misty.com/~don/donflash.html (my xenon "top page")
- Don Klipstein ([email protected])
P
Phil Allison
"Don Klipstein"
242-288 volts.
** Snip rest of this wanker's impenetrable drivel and multiple DEAD links
The electro used in a typical disposable camera flash is 160 uF, charged to
300V - I have a few here.
So from: E = 0.5CVsquared - the energy stored is about 7 joules.
The duration of the flash is close to 1 mS, after which most of the energy
is lost from the cap.
So, 6 joules goes west in 1 mS.
Makes the peak power about 6kW.
...... Phil
D
Phil said:
"Don Klipstein"
That would be average power
Dirk
http://www.transcendence.me.uk/ - Transcendence UK
http://www.theconsensus.org/ - A UK political party
http://www.onetribe.me.uk/wordpress/?cat=5 - Our podcasts on weird stuff
P
Phil Allison
** Close enough to the peak value as well.
You asinine question has no exact answer.
..... Phil
D
Don Klipstein
"Don Klipstein"
More like average around 6 kW, with peak significantlty greater, over
this millisecond.
..... Phil
P
Phil Allison
"Don Klipstein"
this millisecond.
** YOU got the simple math TOTALLY WRONG -
you DROP DEAD STINKING **** !!!
......Phil
P
Phil Allison
"Tim Wescott = Criminal Autistic Asshole "
** Go DROP FUCKING DEAD
- you PSYCHOTIC ASININE TROLLING **** !!!
.... Phil
S
Spehro Pefhany
242-288 volts.
inductance of wiring from the energy storage capacitor to the flashlamp.[/QUOTE]
Maybe a bit optimistic. Typical IGBTs for flash service are rated at
~150A peak collector current.
http://documentation.renesas.com/eng/products/transistor/rej03g1201_cy25cah8f.pdf
Best regards,
Spehro Pefhany
D
242-288 volts.
http://documentation.renesas.com/eng/products/transistor/rej03g1201_cy25cah8f.pdf[/QUOTE]
So ballpark figures are 10J and 50kW?
Dirk
D
Spehro said:
Sounds reasonable (ballpark) -- looks like it is more like 160uF tops
in those wimpy disposable camera flashes.
http://wiki.4hv.org/index.php/Photoflash_Capacitor
Here's a charging schematic:
http://www.geocities.com/lemagicien_2000/elecpage/maxflash/maxflash.html
Neat little circuit.
Dirk
