Dishwasher Control Board Repair
mendit
Nov 11, 2015
Nov 11, 2015
I am trying to repair my non-functional dishwasher and I have found a component on the control PCB that has partially burnt and disintegrated. It is a surface mount item with the markings: ST Z3M A009. It has 3 pins on one side and one longer tab on the opposite side.
I would be very grateful if someone could tell me where to get this component or an equivalent in the UK please.
I have virtually no electronic knowledge but to have the soldering skills to replace the component.
Many thank in anticipation.
73's de Edd
Aug 21, 2015
3,622
Aug 21, 2015
3,622
Sir mendit . . . . .
I read the coding on the device as:
ST electronics being the manufacturer of that device
The actual full device number id is . . . . Z0103MUF
The A009 is being a code date.
This Triac unit specs out as being a 600V 1 amp unit with a gate sensitivity of 3 ma.
Mouser has 2,906 in stock at 84 cents a copy . . .OR . . .
do a search of UK suppliers using the full
Z0103MUF
numbering of the part.
Da Da sheet :
http://www.mouser.com/ds/2/389/CD00002268-310792.pdf
73's de Edd
dorke
Jun 20, 2015
2,342
Jun 20, 2015
2,342
Please post the Brand and Model of your dishwasher.
That way we can be of help:
finding the service manual and guiding you further.
Electronic parts "blow-up" because of some reason,
many times not just a single device with visible damage.
Finding the reason is the way to fix,not just replacing a "blown" device.
"no electronic knowledge"
not a very good point to start with electronic repair...;)
