A
Andrew Holme
I've implemented a DSSS receiver in an FPGA. The code rate NCO is
controlled by an early/late detector. The carrier NCO is controlled by a
Costas Loop. I chose PI gain constants for the control loops by trial and
error but would like to do it more scientifically by analysing stability
using a Bode plot of open loop gain. I always do it this way for analogue
PLLs; but I'm new to z-domain stability analysis.
TimW - I bought your book; but, to be honest, found it quite heavy going.
Nevertheless, adapting some code from the accompanying CD, I came up with
this Scilab script:
kPD = 2^20;
kP = 2^(41-64);
kI = 2^(15-64);
kNCO = 10000;
G = -kPD * (kP + kI/(%z-1)) * kNCO / (%z-1);
G.dt = 1e-3;
scf(0);
clf;
bode(G);
The resulting Bode plot never even passes through unity gain! So is the
system unconditionally stable? Here's a simplified version of the FPGA
code:
`define KP 41
`define KI 15
reg [63:0] phase, rate; // 64 places after the binary point
reg signed [31:0] err; // = Early - Late
always @ (posedge clk) // 10 MHz
if (millisecond) begin
phase <= phase + rate + (err << `KP);
rate <= rate + (err << `KI);
end else
phase <= phase + rate;
It clocks at 10 MHz and applies corrections every millisecond; hence dt=1e-3
and kNCO = 10000.
Is the Bode plot correct?
TIA
this Scilab script:
kPD = 2^20;
kP = 2^(41-64);
kI = 2^(15-64);
kNCO = 10000;
G.dt = 1e-3;
scf(0);
clf;
bode(G);
code:
`define KP 41
`define KI 15
end else
and kNCO = 10000.
TIA
