W
Watson A.Name
IIRC, with the LSTTL chips, the schottky TTLs use a schottky diode
between base and collector to prevent the collector from going below a
certain voltage into saturation, thus speeding up the turn-on. I've
never seen a discrete circuit using this, but is it a workable
solution to put a 1N5711 schottky signal diode between the base and
collector of a 2N2369A or 2N3904 for example, to prevent it from
saturating, and help speed up its switching? I was thinking of
driving an IR LED with a signal that's fairly quick, and I don't think
that an open collector TTL chip would have enough current. But then
maybe parallel open collectors? Or what?
