B
Brian Howie
Yep. I used 3pf accross a current source. I am using a simple current
source for the diode, with 100Meg accross it. I have a bleed of 100Meg
to gnd to stop the node floating. I also have 1Meg from the base of the
cascodes to the fet gates, with 400k to the negative rail. There may be
some blemish somewhere causing the decrepancy.
It might be possible to remove all the dc blockers and use the fact that
there is about 0.4 vgs and make a vbe multiplier with the feedback
resistor without effecting the noise much.
A "good" design should be limited by the inherent noise of the devices
used, not the feedback/bias resisters.
Found it!! I stuck a 470ohm protection resistor in series with the
photodiode; the noise from this doesn't affect the performance at the lower
bandwidth. I get just below 1.5pA/rtHz at 100MHz now.
The ATF551 works better than the P35 device (
http://www.bookham.com/rf/pdf/packaged-fet/1110.pdf) I'm using.
Brian.
Brian Howie
BAE SYSTEMS Avionics Limited
Sensor Systems Division
Crewe Toll Phase II, 1st Floor,
Edinburgh EH5 2XS
Phone +44 (0)131 343 8769
FAX +44 (0)131 343 8941
Email [email protected]
