Disco Strobe light to Camera Strobe
eight08
Apr 16, 2010
14
Apr 16, 2010
14
Hey guys. I was wondering if you could help me with my project.
I have a disco strobe light, potentiometer is at the back, with controls the rate of FPS.
My question is, is there any way to convert it into a camera strobe, just with 1 shot per trigger? How would i convert it? I was thinking of connecting it to a 1 shot multi-vibrator circuit, 555 timer design. I need it to be fast as in sync with the camera's on board flash.
Thanks guys!
Resqueline
Jul 31, 2009
2,848
Jul 31, 2009
2,848
Almost certainly. I don't think you'll need much extra except perhaps for some galvanic isolation for the trigger, since the whole strobe circuit may be at mains voltage.
Please provide us with a diagram, or at least two good shots (of the pcb, top & bottom).
Resqueline
Jul 31, 2009
2,848
Jul 31, 2009
2,848
I believe all you need to do is remove the diode KV65 and replace it with an optotriac (or a reed relay). Then there is the question how to drive the optotriac with the camera.
I believe the camera just connects their flash shoe contact to "ground". If so you'll need a small power supply. A couple of penlight batteries would last a loong time.
Parts: 1 optotriac, 1 resistor, 1 battery holder. Does this sound like a viable solution to you?
eight08
Apr 16, 2010
14
Apr 16, 2010
14
Thanks for your reply!
How fast would the reed relay respond? My camera dose not have the hot shoe mount, unfortunately, it it just a bridge type camera with a pop up flash, I was thinking of triggering it with an LDR trigger, to a multivibrator circuit, connected to an SCR, so as the voltage from the multivibrator fires the SCR, the SCR shorts the connection of the strobe. I just need to find the leads in which to connect the legs of the SCR in the strobe. :D
Oh, and i would like to use the disco part of the strobe too, not totally making it into a camera strobe. Maybe a switch to switch between functions?
Resqueline
Jul 31, 2009
2,848
Jul 31, 2009
2,848
Reed relays are quite fast (a millisecond?) but not anywhere near as fast as thyristors (10 microseconds?) and in particular transistors (0.1 microsecond?).
No need for the opto-triac-isolator if you use an optic trigger. I dont think there's any need for a monostable mvb either, just an LDR and an SCR. I'll try to dig up a circuit.
Yep, a changeover switch will do fine.
(*steve*)
¡sǝpodᴉʇuɐ ǝɥʇ ɹɐǝɥd
25,510
25,510
The issue with firing a flash (at least with cameras having a shutter on the film plane) is that you have a very short time to fire the flash -- often only a few thousandths of a second -- that is true even if the sync speed is 1/60 sec!
I would not recommend any trigger that involves a relay. Admittedly, a reed relay is fast, however an optocoupler is faster, requires less power, and is not significantly more expensive.
Triggering one flash from another flash is actually a relatively simple problem. There are cheap commercial devices, and the circuit is not difficult.
There are some examples here, here, here, or here (and there are many more).
Note that if your camera emits pre-flashes, either to assist focus or for "red eye reduction" then you will have to disable that feature or do something like this.
eight08
Apr 16, 2010
14
Apr 16, 2010
14
Thanks for your reply guys!
Thanks Resqueline!
I built one before, with a solar panel and an SCR which I found in instructables.com, and it worked fine, but upon moving it to a better casing, it suddenly didn't work and I haven't gotten around to that.
Thanks for your examples (*steve*), but I would like to keep it DIY and keep the cost down if possible. The trigger I guess is not a problem.
I've built one before, a wireless one using an SCR and LDR at the camera's flash and it synced fine with a little tweaking at a shutter speed of 1/200s. My camera has a manual flash and it emits one burst.
Those have stopped working and I haven't started troubleshooting as my exams are coming up. Thanks for the help guys!
