S
Stretto
When directly coupling a single supply non-inverting op amp buffer there are
issues that seem to be impossible to fix.
If you simply hook up the source to the op amp without any coupling then any
signal swings below V- of the op amp will be clipped. One can remedy this by
"lifting" the source by biasing it's ground. This requires a resistor in
series, at least in some cases(not sure if all). But doing this attenuates
the signal.
Is there any way to direct couple an AC signal to a single supply op amp
without having these issues(either clipping or attenuation)? I need to
maximize headroom(hence bias it half way between the rails) and have no
attenuation(as to reduce noise reduction. Simply amplifying the signal after
the attenuation won't work).
Maybe there is some configuration of negative feedback that can compensate
for the attenuation resistor in a way that doesn't increase noise? Or maybe
there is another way to directly couple the source that avoids these issues?
the signal.
