Dipole voltage basic query
Discussion in 'Hobby Electronics' started by Martin Lewicki, Apr 23, 2006.
  1. I'm basically knowledgeable in electronics eg E=IR, right-hand rule (or
    is that left-hand) etc...
    Query:
    A Tv antenna dipole receives electromagnetic radio waves from the
    transmitter. As the E and B components interact with the metal a small
    oscillating current/voltage is set up in the dipoles in tune with the
    arrival of each EM wave front. Correct?
    Question:
    What is the level of current/voltage induced in the dipoles? I expect it
    would be very tiny - milli, micro, picco. What might be the actual
    figure? I understand that distance from transmitter will affect strength.
    Marty
  2. atec77
    atec77 Guest
    http://www.google.com.au/search?hl=en&q=determining+dipole+voltages&btnG=Google+Search&meta=
  3. Overall Systems theory can help a little here.
    tranimitter puts out power - through cable -out of antenna, there is
    attenuation of radiowave propagation to the receive antenna and loss down
    the cable to the receiver.
    a tranmitter = power gain (say in units of dBm)
    b cable = power loss (attenuation in dB)
    c Tx antenna = power gain or loss (usually gain in dB)
    d radiowave attenuation = power loss (in dB)
    e Rx antenna gain = power loss or gain (usually gain in dB)
    f cable loss = power loss (in dB)
    g receiver measured power (in dBm)
    Overall Radio system equation( sum of losses and gains)
    a -b +c -d + e -f = g (there are other factors also)
    g the received signal, receivers have a typicall threshold , for say some
    mobile phones it migh be -118dBm
    So what must be received at the receiving antenna must be -118dBm + f -e
    for the receiver to work above it's threshold.
    If we assume cable loss is as 10dB and antenna gain is 10dB then there must
    be -118dBm at the receiving antenna.
    -118dBm can be converted in to uV (based on sa a 50ohm load - because dBm
    is a power measurement and uV is a voltage)
    eg P = V x V / R ==> Hence V = Square root ( P / R).
    Regards
    JG
  4. Phil Allison
    Phil Allison Guest
    "Martin Lewicki"
    ** The signal voltage picked up by a TV antenna is generally in the order of
    a few millivolts per received ANALOGUE station. Digital TV signals are
    considerably weaker. This voltage is delivered into an impedance of 75 ohms
    at the set -so 1 mV equates to about 13 nanowatts !
    If because of distance or unfavourable local geography the signal falls to
    less than 1 millivolt, the picture becomes noisy - ie affected by "snow".
    The power output, location and radiation pattern of TV *transmitters* is
    deliberately arranged so that viewers in the intended zone will get a signal
    of a few millivolts via standard TV antennas on their roofs.
    Those living in close proximity to the transmitter site can use a very basic
    ( small dipole) antenna while those on the fringe of the range will need a
    larger antenna than usual with designed in "gain" to boost the level of the
    signal voltage.
    ........ Phil
  5. Thanks Phil, that's what I was looking for.
    Also thanks for the others, though I'd need more technical background to
    follow it.
    Martin
