DIP Component Identification
Discussion in 'Electronic Components' started by DaveC, Feb 28, 2006.
  1. DaveC
    DaveC Guest
    Hello.. The part I'm trying to ID has the following markings.
    ATS302T
    C3016 794C
    It is a 14 PIN DIP, in the handheld controller for a mini radio sub
    that worked in my fish tank, as seen here...
    http://www.raidentech.com/mirarecorcsu1.html
    It's the only IC, VDD goes to pin 9, while ground is pin 3.. how
    strange I thought.
    The buttons (NO), when pressed ground pins on the chip.
    Left = pin 14
    Right = pin 1
    Up = pin 5
    Down = pin 4
    Turbo Boost = pin 6
    This is how its laid out..
    right 1|----u-----|14 left
    (nc) 2| |13 (nc)
    GND 3| |12 R1 \
    down 4| |11 R1 / ---- C1 --- to ground.
    up 5| |10 -- R2 --- 49.8MHz XL
    boost 6| |9 VDD
    (nc) 7|----------|8 --- off to tx? transistors caps choak .. etc.
    So , some sort of coding , that modulates the carrier?
    DaveC
  2. Ross Herbert
    Ross Herbert Guest
    Looks like the ATS302T (transmitter)and ATS302R (receiver) may have
    been a custom design for that radio control sub. Action Semiconductor
    in China don't list it in their products
    http://www.actions.com.cn/en/index.aspx
    However Mobicon Electronic Components in HK have a data sheet
    http://www.mobicon.com.hk/image/data/_TX2C ATS302TRX2C ATS302R Datasheet(English V1.02).pdf
    Note: you will probably need to copy and paste the
    (English%20V1.02).pdf part to the end of the URL. Also, it is a very
    slow server so be patient.
  3. DaveC
    DaveC Guest
    Thanks.. that's it..
