Diodes purpose in this circuit?
Roman
Aug 17, 2016
Aug 17, 2016
Hi. Sense pins in this schematic are used with diodes. Anyone can explain? And what diodes will work here. No info in datasheet.
Roman
(*steve*)
¡sǝpodᴉʇuɐ ǝɥʇ ɹɐǝɥd
25,510
25,510
They champ the input voltage a diode drop above Vcc
(*steve*)
25,510
25,510
Oh, they are drawn as schottky diodes.
hevans1944
Hop - AC8NS
Jun 21, 2012
4,878
Jun 21, 2012
4,878
You need to protect the inputs of the ADC in the MCU from overshoot, caused by possible parasitic LC ringing in the inductance of the motor winding. High-speed reverse recovery Schottky diodes are necessary because of the high frequency pulses associated with PWM motor current. Not much current is involved, because of the high impedance of the voltage divider feeding the ADC inputs.
