DIODE
Discussion in 'General Electronics Discussion' started by remo123, Jun 2, 2013.
  1. remo123
    remo123
    Jun 2, 2013
    I have seen a sensor circuit in which two diodes are attached i.e One between the signal and power and the other between the signal and ground. why?
  2. BobK
    7,682
    1,688
    That configuration is used to limit the voltage to a little below ground and a little above V+.
Similar Threads
Loading...
