Diode
Discussion in 'General Electronics Discussion' started by sstop, Dec 26, 2010.
  1. sstop
    sstop
    4
    Dec 17, 2010
    Can I replace UF2008 with UF 5408 ?
    Diode is in the primary circuit of PC power supply (HOT side)
  2. davenn
    davenn Moderator
    13,866
    1,958
    have you looked at the data sheets for each of them ?
    if so what were the ratings namely the PIV and current handling of each ?
  3. sstop
    sstop
    4
    Dec 17, 2010
    No, I do not know what to look for !
  4. barathbushan
    barathbushan
    223
    Sep 26, 2009
    Going by the datasheets both have equal reverse voltage ranging from 50v to 1000v
    However the UF2008 has a forward current of 2 amps , and UF 5408 has a forward current of 3 amps
    Hence you can replace UF2008 with UF 5408
  5. shrtrnd
    shrtrnd
    3,824
    519
    Jan 15, 2010
Similar Threads
Loading...
