Diode when wet
marky1993
Aug 5, 2012
4
Aug 5, 2012
4
Hello there... I was wondering what will happen if i let a diode get wet by rain water? I have installed 2 solar panels in our home but i hanged a blocking diode outside. I used 2 diodes (1 each) namely 1n5401 and 1n4001.
donkey
Feb 26, 2011
1,301
Feb 26, 2011
1,301
getting electronics wet is never a good idea. it can cause a short. its best to insulate the exposed wires/ components with a case, heat shrink(for wires) or in an absolute rare occasion tape.
if a single diode gets wet then the electricity can flow backwards using the water as a conductor. this will render the diode a useless piece of equipment in your setup.
at worst if you have 2 diodes close together they can short both the batteries and the panels which again will lead to issues.
marky1993
Aug 5, 2012
4
Aug 5, 2012
4
THanks for the info sir but during the testing stage, i noticed that the max voltage at the bigger panel is 20 and when i connect that to the load, it gives me approx. 2 Amps. will that be enough to use the water as a conductor?
donkey
Feb 26, 2011
1,301
Feb 26, 2011
1,301
I could answer this but it will take along time. simply put pure water will not conduct at all but even rain is not PURE water. the thing that makes water a good conductor is the impurities.
as the impurities are different from drop to drop I could not tell you how much current will be conducted, but rule no1 of electricity is NEVER EVER EVER mix water and electircity. EVER
duke37
Jan 9, 2011
5,364
Jan 9, 2011
5,364
Water will conduct at any voltage if it is not pure. Pigeon poo does not help!
If conduction occurs it may upset the operation of the gubbins but will also give electrolytic corrosion which can give all sorts of problems. Transistors do not work very well with only two legs, so keep it dry.
donkey
Feb 26, 2011
1,301
Feb 26, 2011
1,301
oh and just an addition to my last post
EVER EVER!!!!!!!!!!!!!!
and what duke said is also a great contribution I clean forgot about corrosion
marky1993
Aug 5, 2012
4
Aug 5, 2012
4
I put a waterproof junction box for the circuit to prevent the water. thanks once again... =)
john monks
Mar 9, 2012
685
Mar 9, 2012
685
I remember when I tested electric motors submerged in water. I wanted to make a small submarine. During my last test the motor lasted 10 days under water continuously before failure. In that case the brushes wore out.
Should high tension lines be insulated?
KJ6EAD
Aug 13, 2011
1,114
Aug 13, 2011
1,114
Yes and they are, by air and glass/ceramic insulators.
At an old job, I had an AT power supply submerged in dirty water while powered until it failed. The electrolytic corrosion effects were fascinating. I remember seeing large diode leads concentrically eroded to the point of separation. I didn't look for the deposition site but it was probably the entire ground rail or some of the power rails.
Harald Kapp
13,743
13,743
That's why oil is used to cool e.g. large transformers (and I don't mean the alien species) :)
Alchymist
Apr 16, 2011
26
Apr 16, 2011
26
I do occasional derusting of steel such as machine parts. A bucket of water right from our tap, a scrap steel anode, a rusty part, battery charger and some wire is all that's needed. With the metal parts several inches apart in the water and 12 volts applied, currents in the 2-3 amp range can be expected.
marky1993
Aug 5, 2012
4
Aug 5, 2012
4
how long do you think will the diodes be fully corroded after it first got wet by rain water? I used the blocking diode that I used when i didn't put yet the junction box...
duke37
Jan 9, 2011
5,364
Jan 9, 2011
5,364
I do not think it possible to answer your question. The rate of corrosion will depend on many factors. The wires may last minutes or months. I suggest that you change any components which have corroded leads. I have seen the leads breaking off transistors close to the can.
I use Waxoil which is intended to rust proof cars to keep moisture at bay in equipment which may get damp.
john monks
Mar 9, 2012
685
Mar 9, 2012
685
If you have a 12 volt system I would not worry about it.
Rain water conducts at such a low rate it almost can't be measured.
john monks
Mar 9, 2012
685
Mar 9, 2012
685
Funny you mention that.
Electrolytic capacitors is one example where water and electricity are mixed together.
On a more serious note I understand and appreciate the concern about mixing water and electricity. Normally I would be very concerned about it to but in this situation I believe things are getting a bit out of hand. We are talking about very low voltage and rain water and a diode. I assume this is up high and not siting in a mud puddle. I remember testing rain water for conductivity and I was stunned with how poor a conductor it is. And besides I remember running about 300 meters of audio line from a church to a transmitter site much of it bare in the rain and snow for years and never had a problem.
I'm not to interested in desolving any electrolytes.
