Diode Identification
Discussion in 'Electronic Repair' started by [email protected], Aug 30, 2006.
  1. Guest
    I have a diode which I can't seem to find any information on. I've
    tried all the usual sites and no-one seems to have any matching part
    numbers.
    Its from a LCD monitor power supply - from the recifier circuit (as far
    as I can tell) - its was connected to a 400V cap which is also blown if
    that helps any.
    On the diode:
    GP20-06
    F51
    The logo is a wavy F in a circle.The only company I can find which has
    a similiar logo is frontier electronics, but they dont make diodes.
    Any info would be appreciated.
  2. Guest
    After some more searching - I found another frontier electronics
    company (www.powertech.co.nz) which which seems to make the below model
  3. Tech Data
    Tech Data Guest
    Industrial rectifier by Fairchild. Crosses to an NTE5806, 600PRV-3amp
    www.techdata-kicksass.net
  4. Eeyore
    Eeyore Guest
    I'd guess it'll be a fast recovery diode ( maybe 2 amps ? ) with 600V rating.
    Graham
  5. If that was a 400 volt electrolytic capacitor, and the diode is
    "small", that likely places the diode on the line-voltage side of the
    power supply. That makes things a lot easier. It doesnt have to be
    particularly fast. Just able to handle 2 times 1.414 times the line
    voltage. So a plain old 1N4007 should work fine.
    If it was like a 0.05uF 400 volt capacitor, and the diode is "bigger",
    like a typical 3-amp diode, then it's more likely on the high-frequency
    side of the PS. Then you'll need a faster diode. There are tons of
    them around, check out the 1N51xx line.
