Diode Identification
Discussion in 'Electronic Components' started by Phil Edwards, Jan 21, 2004.
  1. Phil Edwards
    Phil Edwards Guest
    I have an unserviceable diode which has the number F6803R7229 . Can
    anyone help to find an equivalent component? It is a stud diode which
    was mounted on a the same heat sink as a 16A 600V SCR so I am assuming
    that it may be a 16A diode.The unit is part of the voltage regulator
    from Dale Electrics 89KVA alternator. Can anyone help?
