Diode identification help
Discussion in 'Electronic Repair' started by Mike Rossman, Apr 21, 2007.
  1. Mike Rossman
    Mike Rossman Guest
    I'm repairing a fuse junction circuit from a Motorcycle (12v). The owner
    hooked the battery up backward and shorted several diodes on the board. All
    diodes have the markings 1D4 XC. I've tried searching to determine what
    exactly these are with no luck. Any help would be greatly appreciated.
  2. Franc Zabkar
    Franc Zabkar Guest
    1A 400V standard recovery rectifier:
    http://www.rectronix.com/Rectronix/Data/1D1.html
    http://www.datasheets.org.uk/specsheet.php?part=1D4
    http://www.nteinc.com/specs/100to199/pdf/nte116.pdf
    - Franc Zabkar
  3. Mike Rossman
    Mike Rossman Guest
    Thank you so much for your help. It's now a $2.00 fix instead of $180.
