Brand new to the forum so I may be shabby on etiquette.
I'm looking for an axil lead type diode to use in a power cable that "Y's" from a camera to two 24 volt batteries.
I've been told that this is necessary to prevent voltage from going from the battery with more voltage to the battery with less. The reason I need the "axil lead" is because I want to fit the diode inside the 3 pin XLR connector.
The amperage draw will never be more than
10 amps surge at start up.
Have I provided enough information?
Thanx for any responses.
