Diode Equation needs a Knee Transplant
Discussion in 'Electronic Basics' started by [email protected], Sep 10, 2008.
  1. Guest
    I would like to know how to modify the diode equation: I = Io (Exp(eV/
    NkT)-1) to work for a germanium diode. Using Io=10E-12, e=1.602E-19,
    T=295, N=1, and k=1.380E-23 has the correct knee 0.6 for a silicon
    diode. What needs to be changed (or is there a new equation) to move
    the knee back to around 0.3 to model a germanium diode?
    Any help would be greatly appreciated. Thanks
  2. There is no band gap voltage in the "low voltage" diode equation. As
    the applied voltage exceeds the band gap voltage about 0.6 for Si and
    0.3 for Ge a different aproximate equation is used.
    Sorry but I don't know off hand what that "high voltage" equation is.
    George
  3. Guest
    if the equation is not at equilibrium, a potential barrier wont
    develope across the P-N junction so its not that important.
  4. Yes, go the empirical route. You can use ordinary graph paper if you want,
    by graphing log I versus V, or by graphing I versus exp(V). The -1 drops
    out to insignificance, as Tim says. You will find that the data points lie
    on a very straight line, until self-heating kicks in, whereupon the graph
    will start to curve away from the straight line established at low currents
    (constant temperature) where you see the purely exponential side of the
    relationship. For small diodes I agree with Tim's suggested current range.
    You will have to take more than three measurements if you want to see just
    where the curve diverges from the ideal, as a result of self-heating
    effects.
    Try it. I was pretty impressed at how precisely nature mirrors the math.
