Any input on my dilemma much appreciated, I don't have a background in EE design but I'm trying to solve a issue (limiting the voltage) on the following -
Background - 0-10 DC V supply from external source that is monitored on an input pin of a micro controller
Max Vin allowable on MicroC pin is 1.2V
Step 1 is to use a 220K / 30K Voltage divider producing a 0 to 1.2V input into the pin on the MicroC -
Step 2 is to clamp the voltage at max 1.2V in case the V supply rises above 10V
After doing some research I think that using a diode to clamp the voltage should work - connecting the cathode to a 0.6V rail (another Vdivider 16K/4K3 form 3V3 supply) and the anode to the MicroC pin? is this a logical solution?
It the Diode clamp does work if the 3V3 supply goes down does the Diode still protect the MicroC ?
Many Thanks
Many Thanks
