dimming cf question
Discussion in 'Home Power and Microgeneration' started by Tim Thomson, Jan 7, 2006.
  1. Tim Thomson
    Tim Thomson Guest
    Is there any way of dimming the compact flourecent lights.
    Do the dimmers desighned for the tudes works on the compacts?
    What happens when they are hooked up in series half voltage?
  2. Vaughn
    Vaughn Guest
    You have to find a CF that is advertised as dimmable. Most CFs are (more
    or less) clearly labeled "not dimmable".
    Here is a site with a bit of info on dimmable CFs.
    Vaughn
  3. JoeSP
    JoeSP Guest
    There's a reason dimmers are stamped with the words, "INCANDESCENT ONLY"
  4. Drums
    Drums Guest
    Standard dimmers are not for inductive loads.
  5. Richard P.
    Richard P. Guest
    The store I worked at (Home Hardware) sells dimmable CF's... although I have
    yet to try one out. They are pretty expensive, though. We sold way more
    tri-light CF's (7w/15/23w) than the dimmable ones and these work very well
    in a tri-light socket equipped lamp.
