Digital volt meter circuit
Discussion in 'General Electronics Discussion' started by vinod chandran, Aug 27, 2012.
  1. vinod chandran
    vinod chandran
    192
    Jun 21, 2011
    Hi all,
    Is there any digital volt meter circuit which doesn't need external power supply and c programming?. I mean all i need to buy the parts and solder it into a board and connect with my 12v battery. I prefer 3 digit circuit.
  2. (*steve*)
    25,500
    2,840
    There are some which are designed for something like 7 to 24V and which take power from the source being measured.
    But these are built up units. I'm not sure where you'd find a circuit diagram, and these days, much less on e that doesn't use a microcontroller.
  3. vinod chandran
    vinod chandran
    192
    Jun 21, 2011
    Hi steve,
    Thanks for the reply. What about old digital multimeters? Can i turn an old multimeter to a DVM ?, is it possible ?.
  4. CocaCola
    CocaCola
    3,635
    5
    Apr 7, 2012
    Sure why not... Just set it to volts and there you go...
  5. (*steve*)
    25,500
    2,840
    But they require batteries.
  6. vinod chandran
    vinod chandran
    192
    Jun 21, 2011
    Hi Steve ,
    That's the problem. What if i connect voltage from the source to be measured?.
  7. CocaCola
    CocaCola
    3,635
    5
    Apr 7, 2012
