K
Kevin Hendrikssen
Since when is aus.tv a digital TV forum?
Try looking up the word "forum" in a dictionary.
Hmmmm where is it getting the signal from to tune that radio from?
As
far as I know radio stations are not digitised and re-broadcast on
digital are they in which case you will still have poor FM performance
won't you?
There is no circuitry in a STB that could improve the
signal.
David L. Jones said:Digital has MANY advantages over the existing system. I too was
skeptical until I got a STB to enable me to get my favourite shows in
widescreen.
The benefits I've found are:
- Absolutely perfect picture on every channel, all with my existing
crappy antenna. I could hardly pick up SBS at all before, now I get it
perfect, along with all the other channels. Fantastic. Not many people
get a perfect picture on every channel with analog. Sure there is a bit
of pixelisation now and then, but you have to be watching for it. Give
me a perfect picture and a bit of pixelisation over a snowy picture any
day.
- Widescreen. A HUGE benefit IMHO.
- A much sharper picture, and much easier to see and clearer so say
people I know with vision problems.
- The sound is slightly better, but this only a marginal benefit for
me.
- Online TV guides. Marginal benefit, but nice.
- High definition for those with the gear, although Hi-Def is still
ridiculously expensive for the small benefit. i.e. I can't watch any of
my DVDs in Hi-Def.
How do you work that one out?
The broadcast quality that was sent before if received on a TV
with no problems would match the perfromance of the TV, so where would
you see an improvement.
Mr.T said:Telecommunications,
electricity, gas, water,
Why? It's irrelevant to the question.Kevin Hendrikssen said:Try looking up the word "forum" in a dictionary.
David L. Jones said:Never said it was. I can help SOME people that's all.
What part of SOME people don't you understand?
Who_tat_me said:Why? It's irrelevant to the question.
Telecommunications, electricity, gas, water, and many others depending on
state/territory.
Not relevant. aus.tv is an top level newsgroup for the discussion of allKevin Hendrikssen said:When is digital TV not TV?
The average VCR picture resolution quality these days - it wouldntHow much it used to cost is entirely relevant. Your claim was that it only
costs $100 for an STB. The example that I used demonstrates that it costs a
lot more and the $100 that you quoted is only the case as of fairly
recently.
No it isn't. A lot of people have multiple TVs and multiple VCRs.
I's entirely relevant and your claim isn't actually true. With a TV and
associated VCR NOW you can record one program and watch another. If you buy
one STB you can not do that. You have to buy at least two STBs to maintain
the existing functionality. At least two because with an existing VCR you
can program the VCR to tune to any channel and record when you are not at
home. $100 STBs don't generally have an autotune function so if you really
want to retain the analogue functionality you need at least one STB for each
channel that you want recorded while you're away.
RUBBISH. Benefit is subsjective. Most people get an adequate picture. People
like me get a good picture that is more than just adequate. Most people
don't give a damn about EPGs and widescreen so the only real benefit of
digital is a possibly improved picture and most people don't see $100 or
more value in that.
But would they be satisfied with the vastly inferior picture on the non STB
device? If didgital is so great, how could they bear to go back to analogue?
Thought that was you considering the shit you've been writting in this"AJ" = what a dickhead
** The ABC runs two high quality, digital radio signals along with its other
TV signals.
See: http://www.abc.net.au/dig/
Again only for a channel that is sent digital. If its just acting as a** Total gobbledegook !!
** The music signal is **digitised** so does not suffer from the problems
that * analogue* FM does when arriving via a compromised antenna or in a
poor location.
Who_tat_me said:Not relevant. aus.tv is an top level newsgroup for the discussion of all
aspects of AUStralian TV. aus.tv.digital was created for the discussion of
aspects specifically relating to digital TV in Australia. aus.tv.digital is
a digital group. The implication of the other poster's question was that I
was posting to a specifically digital group. I am not.
Phil said:"David L. Jones"
** Questions for DLJ.
1. What does a STB's pic quality look like if the RF out is used to feed an
old TV ??
2. What does a STB's pic quality look like if the composite output is
connected to a VCR video input so the modulator feeds an old TV - so the
STB's signal can be recorded ??
3. What does a STB's pic quality look like if the RF out is connected to the
antenna input on a VCR, then proceeds via its tuner, IF strip, video
detector and RF modulator to an old TV ??
4. How does the above pic quality *compare* with that obtained by using
direct S-Video or Component Video linked to a modern, 68 cm TV ??
The arrangements 1, 2 & 3 are COMMON when STBs are used with old TVs.
The dudes you are debating are likely basing their comments on the pic
quality of 1, 2 or 3.
............. Phil
How do you work that one out? In many cases what is sitting before the
transmitter, or in the case of digital what ever it is that digitises
the signal is pretty much the same stuff. Sure the stations may have
new camera's etc to cater more for digital TV (Widescreen and all that
good stuff that does make digital a good thing), but there ain't
nothing that is going to improve the analogue signal coming off the
stick. The broadcast quality that was sent before if received on a TV
Ok so the ABC has digital stations that's cool and didn't know that.
In that case it makes perfect sense so there would be an improvement,
BUT the orginal poster who asked about radio.....
wasn't specificaly talking about ABC radio,
it was just radio,
so you would be missing
many stations, so the original posters comment as to why the hell would
you run your radio through the TV?
receiver for a FM radio channel then it does SFA
David L. Jones said:The link I posted shows aus.tv.digital only, so unless Google is lying
or not showing cross posted groups, you do post to aus.tv.digital
Easily explained. We've been having a discussion about the benefits ofMichael A. Terrell said:bject:
Re: Digital TV: Why do we have to have it?
Date:
27 Mar 2005 14:56:33 -0800
"David L. Jones" <[email protected]>
Organization:
http://groups.google.com
Newsgroups:
aus.tv, aus.politics, aus.electronics
References:
1 , 2 , 3 , 4 , 5 , 6 , 7 , 8 , 9 , 10 , 11 , 12 , 13 , 14 ,
15
