R
RMD
Hi All,
I'm in a difficult reception area here at Salisbury Heights in
Adelaide. I have a ridgeline which shields me from the Mount Lofty TV
transmitter antennas, and a 33KV trunk mains running across in front
of my antenna complex.
I have a two antenna set-up which I installed in 1996. It consists of
a VHF/UHF Tandy 18 element VHF/UHF antenna plus a 12-element UHF
antenna which I bought from K-Mart (I don't remember the brand). The
two aerials feed into a VHF/UHF Tandy masthead antenna amplifier.
There are also indoor booster amplifiers on the 6 room distribution
system. The antennae system supplies signal to multiple TV's, PVR's,
VCR's, FM radios, & DAB+ radio.
UHF reception of SBS with the K-Mart UHF antenna is excellent, whereas
the Tandy antenna is getting a bit sick up at analogue Channel 10.
Digital TV reception is excellent for Channels 7, 9, 3, and 44 but is
dodgy on Channel 10 and Channel 2. Channel 10 digital is the worst
performing channel.
My Strong PVR gives the following numbers for signal strength/quality
with the Tandy/K-Mart antenna:
(Ch7 83%/95%, Ch9 85%/95%, Ch10 81%/47%, Ch2 73%/50%, Ch44 83%/95%,
Ch28 99%/95%)
The above figures show why digital Channels 2 & 10 are bad performers.
This is so particularly with a north wind which has the 33KV trunk
line producing plenty of impulse noise.
Anyway, I replaced the Tandy UHF/Antenna with a MatchMaster 01M-LP03F
log-periodic antenna. Matchmaster actually recommend the 01MM-DC21A
antenna for my location on their web antenna selection facility.
However, my local Jaycar store had the LP03F in stock and it was only
$79 instead of $149, so I figured I'd give the cheaper antenna a go.
The performance figures seem much the same.
So, I've kept the existing UHF K-mart antenna (which has strong and
excellent performance), and put in the Matchmaster in to replace the
old Tandy UHF/VHF antenna.
I'm only using the UHF performance of the Matchmaster antenna, because
of the old Tandy masthead amplifier requiring separate VHF and UHF
antennas.
with the Matchmaster/K-Mart antenna:
(Ch7 90%/95%, Ch9 85%/95%, Ch10 85%/95%, Ch2 82%/95%, Ch44 82%/95%,
Ch28 99%/95%)
So, the Matchmaster log-periodic antenna has improved Channel 2 and
Channel 10 reception to aproximate the Channel 7 and 9 performance
with the old antenna system.
The FM radio signal strength has dropped compared to the old antenna,
but is still quite workable. The DAB+ radio seems to have perfectly
adequate signal strength and is apparently working well as I write
this.
So far I'm jolly pleased with the results. Channel 2 analog even still
works after a fashion, and is quite watchable in an emergency, which I
didn't expect at all., since the Matchmaster is a Channel 6-12
antenna.
I'll be interested to see what happens with a north wind which usually
has the 33KV trunk mains generating plenty of impulse noise. I have a
heat wave/north wind coming soon, so I ought know how the new
antenna copes in a week or so.
So far I'm very pleased with the results.
Ross
performing channel.
Ch28 99%/95%)
antennas.
Ch28 99%/95%)
this.
antenna.
Ross
