Hello there everyone,
I have an ambitious project and would like some guidance.
my experience is limited to the 555 timer lols 10 years ago. soo I believe its best to be honest.
Soo here we go- I must be certified nuts that I am sure
Functions:
1: So I would like to make a 10 time zone clock with 4 digit 7 segment + 6 DP display with RGB LEDs.
2: an addition of a 10 digit name underneath each as well as a alphanumeric date with
Julian date.
3: Finally There is a display for 2x humidity and temperature sensors. (another 28 segments )
4: USB and WIFI for programming and control.
5: outputs for relays to a motor controller.
The simplest solution I believe is a PIC controller, but there isn't one that will do all this so...its easier to break it down to the individual clocks, and have a master PIC I believe.
In this case, a maxim will do the job I believe of driving the LEDs for each clock, and name.
This results in 11 outputs for LEDs 4 inputs from sensors and one feedback loop from a mains sensor for manual override- is there a way I can reduce the led inputs on a SPI or other bus or even how to go about this on block diagrams?
I am seriously over complicating this I guess.
the xtals are also confusing me as to a refresh rate for displays, and one for the correct timing? the devices are designed to be standalone after being set by an international clock though usb.
Is an fpga approach better?
thanks
Iain
Functions:
Julian date.
thanks
Iain
