C
Chuck Chopp
I have a bird brooder that is used for providing a temperature & humidity
controlled environment for baby birds until they are old enough to maintain
their own body temperatures. The brooder has a digital thermometer on it
that is accurate to within .1 degrees Celsius. The problem that I have with
the unit [and this is common to all brooder designs] is that there is an
internal light that needs to be turned on & off for various periods of time
through out the day, and the light itself produces heat that throws off the
temperature settings in the brooder.
Currently, the heating system in the brooder runs off of 110 VAC, and it
comes with a power inverter to allow it to be run off of a 12 VDC power
source [e.g. cigarette lighter in a car]. The temperature control is a
potentiometer that is used to control the electric heating elements, and
there is a fan that blows continuously to circulate filtered air inside the
brooder.
What I'm looking for is an inexpensive circuit that would allow me to set up
a digital thermostat control for the brooder. I want to use this to
calibrate the potentiometer so I know by reading the display what the
desired temperature is and then look at the digital thermometer to see what
the actual temperature is. A secondary function for the circuit would be to
compensate for the heat output of the light by stepping up the speed of the
fans [I'll get 2 speed fans], disable the light itself and sound an audible
alarm if the temperature in the brooder goes over the thermostat setting by
more than say 1.5 degrees Celsius.
Does anybody have any recommendations on a ready made digital thermostat
unit that I could adapt for this purpose, or a link to schematics for a
circuit that I could assemble from discrete components?
TIA,
Chuck
brooder.
TIA,
Chuck
