Johan Smit
I have a Casio digital recorder, and downloads the files to the PC.
Then I convert the file to standard Windows Wav.
So far everything is fine, and the sound is good, but when I then
write it to CD, it sounds awful. I tried all I can think of, with no
better results.
I can only think that the low sampling rate of 8000Hz interferes with
the CD sampling.
Any solution please?
I was thinking of taking the audio out from the sound card, which
sounds good, to the mic in of another sound card, and re-record at a
better sampling rate.
Problemn is that it is apparently not possible to run two sound cards
simultaneously.
Any help will be much appreciated.
Thank you
Johan Smit
better results.
the CD sampling.
simultaneously.
Thank you
Johan Smit
