Digital propeller clock
Discussion in 'General Electronics Discussion' started by 123, Apr 22, 2013.
  1. 123
    123
    Apr 22, 2013
    Hi. I'm trying to build a propeller clock for a class project using a vcr motor from a sharp vc-h870u. My current problem is getting the motor to work outside the vcr. I've hooked it up to 5 volts, 12 volts, and both and am not having any luck. I've tried googling the data sheet for the motor and have come up empty every time. Any suggestions would be appreciated. Thanks.
  2. BobK
    7,682
    1,688
    Well, it probably is not a DC motor then.
  3. HellasTechn
    HellasTechn
    1,557
    215
    Apr 14, 2013
    Most probably it is a dc motor.
    Could you post a picture of the motor and it leads ? maby that way we might be able to help.
    One other thing you could do is to put it back in the vcr and while in normal operation you could measure the voltages.
  4. (*steve*)
    25,501
    2,841
    I'm with Bob.
    But a picture of the motor and the leads may be useful
