Digital Potentiometers - implementation ?'s
Discussion in 'Electronic Design' started by Jason Stoddard, Nov 15, 2003.
  1. I wonder if somebody can add a couple wrinkles to my grey matter. I am a
    bit new to these. I am looking at a digital potentiometer:
    (DS1866 - http://rocky.digikey.com/WebLib/Dallas/Dallas Web%
    20Data/DS1866.pdf)
    I am putting together a micro controlled circuit for a school project. I
    would like to have a micro output signals to drive the digital
    potentiometer and use it as a dimmer for some LED's or other low voltage
    light.
    My question is on how to read the data sheet to determine how much
    current I can run through the resistor network? Can I run my LED's
    directly through these resistors? or do I need to use these resistors to
    drive another circuit?
    Thanks!
    Jason
  2. I have not looked up the datasheet, but often these chips come
    with different resistor values, the smallest being 10K. That is
    a bit too high resistance for direct control of a led.
    You could use it to control a voltage, from 0V-5V, and use
    and opamp follower to give you a bit more current for your
    led(s).
  3. Luhan Monat
    Luhan Monat Guest
    Jason,
    Digital potentiomenters have their uses - dimming lights is not one of
    them. You can do it, but why not just drive a simple transistor with
    the micro's output. Vary the duty cycle of a series of pulses in
    software (PWM) and control a lot of power with very little loss.
  4. Ban
    Ban Guest
    ||| project. I would like to have a micro output signals to drive the
    ||| digital potentiometer and use it as a dimmer for some LED's or
    ||| other low voltage light.
    ||| resistors to drive another circuit?
    || led(s).
    || Thanks, Frank.
    It will much better to create the dimming by software inside the PIC with
    PWM.
    To the LED I would use this kind of interface, a current source:
    It needs only 1V, the rest is available for the LEDs, it is also short
    circuit proof.
    +5...20V
    o--|<--|<--o
    2N3906 | LED LED
    port ___ |/
    o--|___|--+--|
    4k7 | |>
    V |
    1N4148 - |
    V | |R= 0.66V/20mA = 33 ohms
    1N4148 - '-'
    GND GND
    created by Andy´s ASCII-Circuit v1.24.140803 Beta www.tech-chat.de
    ciao Ban
  5. Yes, 100% agreed. But the question seems to focus on using a digital
    pot, for educational purposes.
