Digital, or analog?
Discussion in 'Misc Electronics' started by Jerry Avins, Nov 1, 2006.
  1. Jerry Avins
    Jerry Avins Guest
    It seems to me important to agree on criteria for deciding whether a
    particular circuit or signal is digital or analog
    One criterion is intended use; there seems to be general agreement about
    that, so I don't address it here. Another criterion is the nature if the
    signal or circuit itself, without reference to intentions. That is the
    topic of this short essay.
    *SIGNALS*
    A digital signal consists of a sequence of a fixed number of discrete
    states, with no intermediate states are allowed. Outside the realm of
    quantum mechanics, a continuous signal is not digital. It can be made
    digital by quantizing it, and different quantizers will convert the same
    analog signal into different quantized signals. As far as I know,
    digital signals exist only as abstractions and in computer circuits. I
    would be delighted to learn of exceptions.
    *CIRCUITS*
    A circuit intended for a digital application has a fixed number of
    discrete input and output states. The useful states are limited to those
    common to both input and output. For simplicity of design, the number of
    states is usually chosen to be 2, although other arrangements are
    possible and some have been utilized. States are represented at outputs
    as voltage or current ranges, and recognized at inputs in the same way.
    The thresholds need not be the same at input or output. For example, the
    specification for the 74LS logic family requires a high-level (1) to
    equal or exceed 2 volts and a low level (0) to be no more than .8 volts
    at the input, and guarantees that a 1 will be at least 2.4 volts and a 0
    no more than .5 volts at the output. That specification makes the
    devices well suited for digital use, but it defines them as analog
    devices by defining voltages which are, as far as states go, ambiguous.
    A CMOS CD4011B makes that point better. It is a quad 2-input NAND gate.
    With a 15-volt supply, a 1 is 11 volts or greater, and a 0 is 4 volts or
    less. The output swings between .05 and 14.95 volts when lightly loaded,
    and can sink or source more than 5 ma at 4 and 11 volts. The /intended/
    use of a NAND gate makes it digital devices, but these are inherently
    analog by construction. Their inherent analog nature seen by connecting
    a 1 megohm resistor from output to the inputs tied together. You will
    have an analog amplifier with 23dB voltage gain and much higher power
    gain. With capacitive coupling, the four gates can be connected as two H
    bridges that will deliver 18 milliwatts per channel into 1500 ohms. To
    be truly digital, a device must have discrete states, and be incapable
    of exhibiting any other state.
    That situation is approximated by cross coupling a pair of the gates to
    make a set-reset flip-flop. Now there are only two stable states, but
    the in-between states still exist as transient states passed through
    when the device is in transition. Rise and fall times greater than zero,
    and the well known but often ignored metastable state attest to that.
    http://www.interfacebus.com/Design_MetaStable.html As far as I know,
    digital circuits exist only as abstractions and on schematics. I would
    Jerry
  2. Jerry, that's good work on a rational foundation for the terms.
    I think, however, that the significant quibbling comes in only on
    boundary cases where the distinction gets blurred, and it's just
    always going to be tough to avoid semantic arguments popping up there.
    For example, even with "digital" devices, by your definitions, at both
    ends of a circuit board trace, the trace may still need carefully
    designed termination and interference isolation which are often best
    treated as "analog" phenomena.
    Although your definitions generally hold, there's still plenty of room
    for argument and confusion at the boundaries. Because of that, I
    don't think the problem of whether certain things are really "digital"
    or "analog" is going to be solved with world-class
    unanimously-approved definitions.
    Eric Jacobsen
    Minister of Algorithms, Intel Corp.
    My opinions may not be Intel's opinions.
    http://www.ericjacobsen.org
  3. Ron N.
    Ron N. Guest
    I remember an old-time engineer once telling me "There
    is no such thing as digital". We merely interpret certain
    behaviors of analog circuits as transitions, noise, or
    metastability, etc. and then attempt to ignore those for
    our convenience, or at our own peril.
    Of course, he was talking about the real world. We are
    free to make abstract models, but should not confuse
    a model with some engineering reality, especially if
    a circuit is working near its limits of behaving similar
    to our first-order models.
    So I would agree with you that digital circuits exist only
    as abstractions.
    However, there is also no such thing as analog. It is
    merely a model where we assume that some continuous
    curve or function is associated with our measurements
    of what are actually numbers discrete quantum events
    (the measurements are usually far too course to
    notice the error).
    If the quantum events are below some noise floor and
    you are already ignoring this noise floor, then a continuous
    model might be the computationally or cognitively more
    efficient tool of abstraction.
    So, as to the question about whether some circuit or
    signal is digital or analog, I would say the answer
    depends on which model best serves your specific
    purpose or question regarding the given circuit or signal.
    For some things DSP engineers do, the answer might
    well be both.
    IMHO. YMMV.
  4. Yes, our world is analog, isn't it?
    I agree that the digital world is an abstraction, therefore not real.
    But what is our world or what is real? (keeping the technological
    perspective rather than philosophical). Isn't it because our sensors
    integrate incoming signals so that they appear continuous? (I prefer
    continuous rather than analog, as opposed to digital). Because our world,
    the real world, is what we perceive using our natural sensors. But this is
    the macroscopic world, in the microscopic one (as you mentioned quantum
    mechanics) it could be the other way around. The continuous signals might
    be the abstraction.
    Adrian
  5. Jerry Avins
    Jerry Avins Guest
    Better say more. Make before break, or break before make? We're looking
    at transitions here. Even with SPST, contacts bounce
    Jerry
  6. Ron N.
    Ron N. Guest
    The first time I tried to make a toggle flip flop out of
    relays (in junior high, I think), it went into metastable
    oscillation, dependent on the power supply voltage.
    Another DPDT relay (there were scavenged discards)
    had one bad (randomly high resistance) contact.
    Try again. :)
    IMHO. YMMV.
  7. Ron N.
    Ron N. Guest
    Said by somebody who's never put a VOM across a batch
    of old rusted relays (scavenged from dead pinball machine
    parts found in a outdoor scrap heap I think).
    Your abstraction does work a bit better with new ones.
    IMHO. YMMV.
  8. Jerry Avins
    Jerry Avins Guest
    Arcing contacts? Zero risetime?
    Jerry
  9. Ron N.
    Ron N. Guest
    So what resistance value, and for what duration, would you
    call closed?
    Do you think that all "open" relays have zero resistance?
    IMHO. YMMV.
  10. I don't think it is possible to say enough to convince some
    folks.
    I'd say a light switch is another excellent example of something
    clearly digital. That can be compared with a large variable
    resistor (a "light dimmer") which is analog.
    With a switch, the light is either on or off. With the dimmer,
    the light can be set half way between any two other points.
    One is discrete, the other is continuous. Digital, and analog.
  11. Ron N.
    Ron N. Guest
    That's what I get for looking at the wrong pin of a DPDT
    relay. :^)
    In my case, it was what voltage, frequency and duration
    of an oscillating relay pair would close the next (rusty)
    relay downstream. There was also the amplitude of
    whacking the side of the breadboard. Analog.
  12. Jerry Avins
    Jerry Avins Guest
    You could say the same about a door, but degree matters, especially to
    the obese.
    Jerry
  13. Ron N.
    Ron N. Guest
    I can't remember where, but I seem to recall some
    ultra high-speed photography of the formation of an
    arc. It didn't look like it was happening instantly.
    Or does Richard count that first electron at "closed"?
    IMHO. YMMV.
  14. Bob Myers
    Bob Myers Guest
    Circuits and signals themselves are neither digital nor
    analog, even though we unfortunately do tend to classify
    them as such.
    The terms "digital" and "analog" properly refer only to two
    different means of encoding information, in this context
    on to an electrical signal. The signal itself remains just
    electricity no matter what we call the encoding, and all
    signals and circuits obey the same basic physical laws, etc..
    The true distinction between these two arises SOLELY in
    how we interpret the signal (or similarly, how it was
    intended to be interpreted).
    In an "analog" encoding, some parameter of the electrical
    signal (generally, either voltage or current, but there are
    other possibilities) is manipulated such that it varies in a
    manner directly related to the variations seen in the original
    information source - for instance, a voltage which is caused
    to vary in the same manner as a sound wave, in the case of
    an "analog audio signal." And hence the name itself - the
    voltage is varying ANALOGOUSLY to the original, hence
    "analog" encoding.
    Similarly, in a "digital" information encoding or transmission
    system, various states of the transmitted signal correspond
    to numeric values - or more generally, symbols - and must
    be interpreted accordingly. Again, the name says it all -
    we're not sending something that directly represents another
    thing, but instead are sending symbols or "digits."
    Neither term NECESSARILY implies a lot of what are
    commonly thought of as the distinguishing features of
    either; for instance, "analog" does not necessarily imply
    that the system is either continuous or linear, even though
    many common analog systems are both. Similarly, "digital"
    does not necessarily imply a discrete or sampled representation,
    and certainly is not limited to a straight binary encoding -
    although again the vast majority of "digital" systems exhibit
    these characteristics.
    From this perspective, arguments as to whether the world
    itself, or basic natural phenomena, etc., are "digital" or
    "analog" are meaningless; the world is what the world is,
    and these terms only refer to methods for encoding
    information which describe some real, original thing.
    We still refer to circuits themselves as "digital" or "analog"
    primarily because of the optimization of that class of circuits
    for dealing with that sort of information, but again the ciruits
    themselves ALL behave according to the same laws of
    physics. And there are certainly types of circuits which
    don't fall into either category - power systems being the
    most obvious example. (The transmission of power does
    not involve the transmission of information, so to speak of
    power engineering as dealing with either "analog" or
    "digital" is just silly.)
    Bob M.
  15. Then obesity is clearly analog. But the described switch contacts
    are not...
  16. By definition, it implys that it is continous. Linear, no, but
    continuous is essential.
    Discrete, yes, again by definition.
    I don't believe that necessarily most are binary nor sampled.
    From this perspective, if you want to make up your own
    definitions, and so does everyone else, what point is there to
    discussing *anything*?
    You are denying that the standardized definitions are correct,
    and that is an absurd stance to take, which makes *nothing* you
    say worth discussing.
  17. Ron N.
    Ron N. Guest
    I disagree. Many standardized definitions are committee
    compromises, and have sometimes what comes out of a
    committee has little to do with what real people try to mean
    or understand when using those words (especially if a
    committee has gotten politicized or influenced by marketing
    agendas).
    (in general. not expressing an opinion on digital/analog).
    IMHO. YMMV.
  18. I was not referencing just *any* definitions. I say *those*
    definitions. They are not in dispute by any reputable source.
    You stake *your* reputation against the entire industry when
    you deny they are correct, and that is simply absurd!
    So we are going to ignore indisputably good standardized
    definitions that the industry (not to mention the Federal
    government) uses, and you think that is going to in any way
    assist in discussing this topic???
  19. Of course to make it work as an analog circuit... components had
    to be added. Which means that was *not* the same "circuit"
    which functions as a digital circuit, even if it used the same
    IC.
    Circuits may or may not be analog or digital, though *clearly*
    some are one or the other. Signals *are* one or the other, by
    definition.
  20. This is a general prerequisite for any kind of
    communication, digital or analog ;-)
    That is demonstrably incorrect. All circuits that have a
    physical instantiation are analog, as are the signals that
    they process.
    [snip fairly lucid description of analog encoding]
    In and of itself, a digital state has no representation in
    the physical world. To instantiate or process a digital
    state, it must be encoded into a voltage/current analog.
    People have been known to group binary states into a
    multi-state logic and represent the combined states with a
    single value of voltage/current analog. If you group enough
    binary states together the analog of the digital value
    becomes indistinguishable from continuous.
