Digital camera flash trigger..............
Discussion in 'Electronic Design' started by [email protected], May 18, 2006.
  1. Guest
    Rolf wrote:
    Most digital cameras has one or more pre-flashes so that a "normal"
    optical trigger for a remote flash will not work. (It triggers on the
    first pre-flash)
    Has anyone seen a fairly simple circuit for solving this problem. I
    have seen some that uses counters but that doesn't solve the problem as
    some cameras seems to not use the same # of pre-flashes every time.
    However the main flash seems to trigger at about the same time. Maybe a
    hold-off (non re-triggerable monostable F/F) and a gate circuit could
    work.
    Any ideas?
    Rolf
