DIGATAL CONTROLLED DECADE RESITOR
Discussion in 'Electronic Design' started by RealInfo, Apr 8, 2013.
  1. RealInfo
    RealInfo Guest
  2. Bill Sloman
    Bill Sloman Guest
    Uses witches to connect any one (or more) of a range of resistors
    between the input terminals.
    It could be latching reed switches, or it might be semi-conductor
    switches - most likely big MOS-FETs.
  3. Bill Sloman
    Bill Sloman Guest
    What's spooky about switches? It's an obvious typo - though not
    obvious enough for me to have caught it.
    I got it right twice in the line you snipped
    "It could be latching reed switches, or it might be semi-conductor
    switches - most likely big MOS-FETs. "
  4. Phil Allison
    Phil Allison Guest
    "Bill Sloman"
    ** Did you bother to read the specs ?
    At all ?
    ** The max input power is 1W.
    I suspect one or two, digitally controlled MOSFETs are involved.
    The specs leave far too much to the imagination.
    Don't even say what the voltage ratings are.
    .... Phil
  5. Imagine a 4-quadrant MDAC with the (buffered) voltage on the terminals
    as the reference. Say the DAC controls a bipolar current source.
    Load the DAC with a code representing G= 1/R(simulated) and you're
    done (conceptually, anyway), since I = V*G = V/R(simulated).
    Range switching probably uses small relays.
    There will be an interesting array of possible error sources etc. in
    this sort of thing, but most instrumentation uses 10uA-10mA currents
    and reasonable voltages.
  6. Bill Sloman
    Bill Sloman Guest
    Which is why I fancy latching relays or MOS-FET switches and an array
    of real resistors. There aren't any significant DC off-sets in that -
    give or take some thermocouple voltages, and with latching relays or
    MOS-FETs you aren't dissipating enough power to generate much in the
    way of temperature differences.
    There's nothing particularly horrible in that kind of solution. Your
    16-bit MDAC solution probably offers finer resolution, but at a
    considerable cost in circuit complexity and extra error sources.
  7. Bill Sloman
    Bill Sloman Guest
    The unit is powered by four AAA cells - despite Phil Alison's
    scepticism I did read the specs. That's compatible with switching
    using latching relays, but I don't think you'd get much battery life
    if they were being used to keep regular relays closed.
  8. "real resistors" is also more their speciality - they manufacture
    precision resistance standards.
  9. Syd Rumpo
    Syd Rumpo Guest
    Yes, Bill. It was what's known as a 'joke'. Not a very good one,
    admittedly, but also not a slight on your integrity, ability or virility.
    Cheers
  10. Bill Sloman
    Bill Sloman Guest
    That makes a change. Some of our regulars don't seem to feel that a
    post is complete until they have managed to impugn all three.
  11. Dunno, maybe. But it is strange there is no specific voltage limit as
    far as I can see. There is a simple 1W dissipation limit, like you might
    get if you used 1W resistors. And there are "30 calibration resistance
    values" to set during calibration. Which is about what you need for a
    binary stepped resistance chain isn't it? 0.1ohm to 24M, ~30 bits.
    But there are other explanations for all the above.
