Spehro said:
Fred Bloggs wrote:
[..SNIP..]
If wideband differential to single-ended conversion is required with
minimal input loading, then you have this option in CFB- trim the R's
in-:
Please view in a fixed-width font such as Courier.
R R R R
COM | |\ | | |\ |
| >-------+ | >------+-> 2x(V2-V1)
V1 >--------+ |
V2 >--------------------------------+
Why would you use that nastly asymmetrical configuration instead of
the below?
Vo = (Vinv- Vnon-inv) * 2 * Rf/Rg
V(inv) |\|
o----------|+\
| >--+ _R_
+-|-/ | +-|___|-+
| ___ | _R_ | |
+-|___|-+-|___|----| |
| Rf | |\| |
.-. +--|-\ | Vo
| | | >-+---o
Rg | | +--|+/
'-' Rf | |/|
| ___ R__ |
+-|___|-+-|___|----+
| >--+ | | R
o---------|+/ '-'
V(non-inv) |/| |
GND
Thanks both,
I wasn't specific about the application.
The application is an output amplifier for a 300MHz clocked DDS,
with an output signal up to 150MHz or a bit less. It has
differential outputs, great for differential input mixers,
but less usefull for something else.
So the only choice to go single ended is the 4 resistor
subtractor with a damn fast amp such as the THS3001 CFA with
a BW of 420MHz(@gain=1), slewrate 6.5V/ns and 100mA output
current.
There are very few parts available and building my own is
not very rewarding either.
Rene
