VMI said:
I looked around but nowhere I whas able to find a schematic of a
differantial probe.
It's main use is to measure with a scope on smpsu's and the like.
I know we can remove the ground lead from the scope, but where then is the
protection left in the case of...
Anny ideas or info?
Marco
Biggest problem is getting enough common mode rejection and sensitivity.
A dual trace scope usually has a subtraction feature, but you have to
keep the whole input inside the dynamic range of each channel. Then
when you subtract them, you get the thing you really want to look at,
but it's really small. And even excellent CMRR at the scale factor
you need to use ain't enough by the time you subtract them.
If you try to crank up the gain, the individual
channels saturate and make a mess of things.
Even if the scope has super CMRR, you still need perfect balance
in the probing system. Making a homebrew differential probe will
be an exercise in futility.
What you really need is a probe that's isolated so you can hook
the "ground lead" of a single channel on something that's not really
ground. But wait, such a thing exists.
And I even have one for sale here:
There's a Tektronix A6902A for sale at:
http://nm7u.tripod.com/homepage/te.html
mike
Return address is VALID.
Toshiba & Compaq LiIon Batteries, Test Equipment
Honda CB-125S $800 in PDX
Yaesu FTV901R Transverter, 30pS pulser
