Differential Configuration for a Floating Signal
Discussion in 'General Electronics Discussion' started by AdamZ, Jun 30, 2016.
  1. AdamZ
    AdamZ
    18
    Mar 17, 2016
    Why is it necessary to use biasing resistors for a floating signal in differential mode of a DAQ card (analog)? What would happen if it was kept floating?
    NI link:
    http://www.ni.com/white-paper/3394/en/
  2. AnalogKid
    AnalogKid
    2,497
    718
    Jun 10, 2015
    The article explains in three places why it is necessary. Which parts do you not understand?
    ak
  3. AdamZ
    AdamZ
    18
    Mar 17, 2016
    It says:
    "If bias resistors are not used in a differential...when measuring floating signal sources, the measured signals can be unstable or at positive or negative full-scale range of the instrument."
    But it doesn't give an explanation as to why it would become unstable. I'd like to understand the mechanism.
  4. BobK
    7,682
    1,688
    What is the voltage between a floating voltage the ground of the instrument?
  5. hevans1944
    hevans1944 Hop - AC8NS
    4,606
    2,151
    Jun 21, 2012
    Differential amplifiers, even those with FET inputs, have bias currents at their input terminals. These currents need to be returned to circuit common or they will charge up the capacitance between each of the input terminals to circuit common and drive the amplifier toward either the positive rail or the negative rail, depending on which bias current is greater than the other. With a very high input impedance FET front-end, with very low bias currents that are carefully matched, the process can take days or weeks to occur. When you go to troubleshoot the problem, it goes away as soon as you probe the inputs because the probe discharges the "stray" capacitance.
    I have built instrumentation amplifiers (in the 1970s) with bias resistors as large as 100 meg-ohms, but these were experimental R&D projects. One to ten meg-ohms is a reasonable value to use and will have no effect on the signal from a reasonably low-impedance source. The resistors should be matched in value for best common-mode rejection performance.
    AdamZ likes this.
  6. AdamZ
    AdamZ
    18
    Mar 17, 2016
    Perfect explanation, as usual!
  7. hevans1944
    4,606
    2,151
    Jun 21, 2012
    Oh, I forgot to mention that smaller-valued bias resistors are better, as long as the application can tolerate the decreased differential input resistance. Smaller valued bias resistors decrease the differential offset voltage created by the bias currents, and also decreases the Johnson (thermal) noise created in the bias resistors, hence, lowers the input noise voltage, too. We only went to 100 meg-ohm bias resistors because we were working with extremely high-impedance sources. Everything associated with the inputs had to mounted on Teflon insulating posts, but that's an entirely different problem.
    AdamZ likes this.
