wiping gooey flux all over the place and then messing around again with carrying the solder to the joint is just totally impractical
When I solder PCB, I just cover all the surface with liquid water soluble flux, it takes seconds
Don't think I use the same flux for all purposes. Actions "take to to the pad + bring the solder to the pad + make joint" won't take more time then "load tip (if solder is set somewhere near) + take solder to the pad + make joint".
When I work with wires, I rarely have to solder wires, twisted like that. More regular is situation when I have to tin stripped wires, then I just stick every wire in the flux, it takes very little time. After that I don't need to degress from soldering itself.
NOW let me see you do the same for a PCB with masses of joint like the ones I build....
Well, looks like I should make a vid about soldering PCB im my way.
At least, I hope, you'll admit that your words about dry joints were hurried, as joint, made by "tip loading" method isn't dry.
P.S. By the way, am I doing direct applying soldering right?
