Different Phase Shift Oscillator
Discussion in 'Electronic Design' started by Phil Allison, Oct 31, 2007.
  1. Phil Allison
    Phil Allison Guest
    "The Phantom"
    ** The link does not say what you claim.
    Yawn .......
    ........ Phil
  2. The Phantom
    The Phantom Guest
  3. Phil Allison
    Phil Allison Guest
    "The Phantom"
    "Phil Allison"
    ** Probably.
    But the link does not say what YOU claimed.
    ** RF will need to be bigger.
    Go find a site that has the WHOLE story about such oscillators.
    Cos that one is crap.
    ......... Phil
  4. The Phantom
    The Phantom Guest
    This last question may seem ambiguous. What I mean is to add one more CR
    section to the schematic given in the .pdf file.
  5. I would recommend that you use Rf >= 12.2*R as a minimum.
    By experiment, Rf>=6.27*R sustains oscillation, with perfect
    parts.
  6. The Phantom
    The Phantom Guest
    Then let me put it this way. Is the author correct that the criterion
    for oscillation is RF > 12R? And if another CR section is added, what will
    be the criterion for oscillation?
  7. The Phantom
    The Phantom Guest
    I didn't say that it did, Phil. My statements were based on my own point
    of view about voltage to current conversion followed by current to voltage
    conversion.
  8. The Phantom
    The Phantom Guest
    For this case, the exact result I get is Rf > 56*R/9 = 6.222222*R
    Are you getting these numbers from simulation?
    Compare this circuit to the one in:
    http://en.wikipedia.org/wiki/Phase_shift_oscillator
    Leaving out R1 makes a substantial change in performance.
    Consider the passive phase shifting network in the .pdf file. The signal
    applied to the node labelled Vi is converted to a current Is at the summing
    junction of the op amp, with a transfer ratio of Is/Vi amps per volt. The
    passive network is acting as a voltage controlled current source into the
    summing junction. The op amp is acting as a current controlled voltage
    source and must supply a transfer ratio of -Vo/Is volts per amp to sustain
    oscillation. So, the magnitude of the op amp's transfer ratio Vo/Is must
    be equal to the passive network's transfer ratio Vi/Is, which for this
    circuit is 12 volts per amp when the R's and C's are all unity, whereas for
    the one given on the Wikipedia page it's 29.
    There was a thread some years ago where somebody wanted to use a bipolar
    transistor as the active device and get a phase shift oscillator to work at
    a very low supply voltage.
    Usually when the phase shift oscillator is shown with a bipolar (in
    descriptions found on the web), the load impedance of the transistor and
    its bias network isn't dealt with properly. With a FET, one could assume
    the input of the FET is very high impedance, probably negligible with
    respect to the network.
    With a bipolar, I wonder if it might be more suitable to use this
    topology and just design for a low input impedance, almost a summing
    junction. Don't have an (un-bypassed) emitter resistor and set the gain
    with a resistor from the collector to the base, with appropriate biasing
    arrangements. Could this oscillate with even lower supply voltages than
    the standard topology?
    This same basic topology can also oscillate if the resistors are replaced
    with capacitors, and the capacitors with resistors. The feedback resistor,
    Rf, must become a capacitor, because it obviously can't be an oscillator
    with only two capacitors.
    It seems that this topology might be able to oscillate with less "hot"
    bipolar transistors.
    It's well known that the standard 3 section topology (with equal R's and
    C's), voltage in and voltage out, needs a voltage gain of 29. Sometimes a
    4 section version is given, and this version needs a voltage gain of 901/49
    = 18.3878. With even more sections, the required gain continues to drop.
    A 5 section version needs a gain of 15.4354 and a 6 section version needs a
    gain of 14.1179. Tapering impedances can reduce the required gain even
    more.
    But the topology shown in the referenced .pdf, with equal R's and C's,
    only needs a "gain" of 12 with 3 sections, and only 6.2 with 4 sections. I
    wonder what can be done with modest tapering of impedances.
  9. Phil Allison
    Phil Allison Guest
    "The Phantom
    ** " Here is one that only needs a gain of 12
    Is the author correct about the required gain?"
    That is a claim that YOU posted that is NOT in the link.
    Don't be such a PITA, fucking LIAR.
    ........... Phil
  10. Phil Hobbs
    Phil Hobbs Guest
    As long as the loading remains small, N cascaded RC sections give
    H**N(f) = 1/(1+ (omega RC)**2)**(N/2) <) -N atan(omega RC).
    For a large number of sections and omega << 1/RC, the phase angle is -N
    omega RC. Setting that as pi, we get the gain at f.pi:
    H**N(f.pi) = -1/(1+ (pi/N)**2)**N/2 which in the limit N-> infinity is
    -1.0.
    So if you ignore loading, you can make a phase shift oscillator with any
    gain above 1 (see our earlier thread about RC networks with gain).
    Cheers,
    Phil Hobbs
  11. Yes. I threw it into LTspice with an initial condition that
    bounced it into oscillation and stepped the feedback
    resistor through a small range to see where the amplitude
    just barely grew.
    I have the feeling that the original circuit could also
    benefit from differing R and C values in the phase shift
    network, but had no luck with just guessing changes that
    would increase the loop gain. I have to get past the mental
    block about current versus voltage output for the network.
    How do you see the ratios of feedback to grounding
    resistance as gain. It is just an arbitrary resistor ratio.
  12. Tam/WB2TT
    Tam/WB2TT Guest
    How do you get 29? For a single RC network the loss at 60 degrees is about
    2. So, you would need a gain of 2**3=8.
    Tam
  13. The Phantom
    The Phantom Guest
    That's only if the successive CR sections are separated by unity gain
    buffers. Otherwise, the later sections load the earlier ones and that
    changes the attenuation and phase shift.
  14. Tam/WB2TT
    Tam/WB2TT Guest
    Yeah, figured that out. The gain of 29 only holds if the three sections are
    identical. If the succeeding sections are higher impedance then you need
    less gain. (per SWCAD). I have seen the number 8 quoted in the literature,
    must have used 2 emitter followers.
    Tam
  15. The Phantom
    The Phantom Guest
    From left to right, label the first section as C2-R2, the second as C1-R1
    and the final cap as C. Define a non-existent resistor as R (to be used in
    the math). Select a value for R and C, and set C2 = 9*C, R2 = R/9; set C1
    = 3*C, R1 = R/3. Then the condition for oscillation is Rf > 3.852*R. This
    is with scaling of 9:3:1.
    Similarly, with scaling of 100:10:1 the condition for oscillation is Rf >
    2.442*R.
    If you have a voltage controlled voltage source (just a voltage
    amplifier), with input Vi and output Vo, the ratio Vo/Vi volts per volt is
    called the voltage gain, or just "the gain". Given a current controlled
    current source, the ratio Io/Ii amps per amp is called the current gain, or
    just "the gain" when the parties to the discussion understand that it's a
    current amplifier.
    What if you have a current controlled voltage source with a transfer
    ratio of Io/Vi amps per volt? Is not the transfer ratio a kind of "gain"?
    Anyway, that's what I mean by "gain".
    And, in fact, the simple inverting amplifier that you would have if the
    phase shifting network in the referenced circuit were replaced by a single
    resistor, Ri, between Vi and the minus input of the opamp would have a
    voltage gain given by -Rf/Ri, an arbitrary resistor ratio.
    The standard voltage in, voltage out, equal R and C, 3-section phase
    shifting network has a "gain" (voltage transfer ratio) at the frequency of
    oscillation of 1/29. This "gain" doesn't depend on the impedance level of
    the network; the output voltage of the (unloaded) network is always 1/29 of
    the input voltage at the frequency of oscillation.
    The network under discussion:
    http://www.digital.ee.eng.chula.ac.th/2102384/download/OSC.pdf
    has the property that the current delivered to the minus input of the
    opamp, at the frequency of oscillation, varies with impedance level. If
    the current delivered to that node is called Is, then the ratio Is/Vi is
    1/(12*R), and the "attenuation", if you will, of the network increases with
    impedance level. This "attenuation" must be made up by the opamp, and we
    see that as R gets larger, then Rf also becomes larger.
    If you consider the "canonical" network, with R and C equal to unity,
    then that number 12 in the 1/(12*R) expression becomes the current to
    voltage transfer ratio of the (opamp + feedback resistor), which is acting
    as a current controlled voltage source.
    The dependence on impedance vanishes if you take the ratio Rf/R, so this
    is a fundamental property of the circuit. To repeat, it's the "gain"
    (current to voltage transfer ratio) of the (opamp + feedback resistor)
    circuit with unity R's and C's.
    I probably should have explained this point of view in more detail in the
    first post, but I had been playing with the circuit for a while and it had
    become familiar to me.
  16. The Phantom
    The Phantom Guest
    Have a look at the expression for the feedback resistor at:
  17. Fred Bloggs
    Fred Bloggs Guest
    That's a nice well-written little tutorial. There's nothing new about
    that particular topology, you can find it many linear op amp application
    notes dating back 35 years, and it is the one most used because the DC
    output level is easily set and common mode response is eliminated. In
    fitting this particular arrangement to the ideal Barkhausen block
    diagram, the op amp portion is broken into two parts, the differentiator
    with gain is included in the Barkhausen feedback block along with the
    RC's, and the low output impedance op amp drive is accounted for by an
    ideal virtual unity gain non-inverting buffer. You might look at
    sensitivity of wo with respect to component values before you add
    additional sections, and you would not the op amp GBW to figure into the
    oscillation frequency with any significance.
  18. The Phantom
    The Phantom Guest
    Can you cite a manufacturer's AN #? In particular, do you know of any
    that provide analyses of the factors you mention? Usually, they just give
    a circuit and expressions for required gain and frequency of oscillation.
    I've dug a couple of interesting old papers on the topic and posted them
    over on ABSE, under the subject "PSO paper #x".
