Different in voltage of 3 phase
Discussion in 'Microcontrollers, Programming and IoT' started by RTYTYBTRYRTY, Dec 25, 2018.
Thread Status:
Not open for further replies.
  1. RTYTYBTRYRTY
    RTYTYBTRYRTY
    Dec 25, 2018
    Hello
    Why there is different in voltage of 3 phase 410V 423V 419V Red green blue
  2. Harald Kapp
    11,981
    2,807
    Insufficient information. Please elaborate.
    Are these measured voltages or is this a theoretical question?
    Are these phase-to-phase voltages or phase-to-neutral?
    Are the colors in any way important?
  3. Minder
    Minder
    3,181
    690
    Apr 24, 2015
    If measuring to neutral and there are single phase loads between the phases and neutral then varying 1ph loads will cause unbalance.
    M.
  4. Bluejets
    Bluejets
    5,254
    1,101
    Oct 5, 2014
    No wonder this Op has the stutters......"RTYTYBTRYRTY"
    If those 400v levels are phase to neutral, what is the phase to phase level (1000V..??)
  5. Kiwi
    Kiwi
    383
    99
    Jan 28, 2013
    As requested, we need more information.
    Is this generator or mains supply?
    Voltage will be phase to phase, not phase to neutral. Phase to neutral will be about 240v for your system.
  6. Harald Kapp
    11,981
    2,807
    Put the same load on each phase.
  7. Bluejets
    Bluejets
    5,254
    1,101
    Oct 5, 2014
    Outside your house and mine as well but anyone's guess what the Op is playing with.
  8. Harald Kapp
    11,981
    2,807
    @RTYTYBTRYRTY : You're firing questions at us without showing that you consider the responses given, less an understanding of 3 phase systems.
    Please get informed about the basic operation of three phase systems (here's another link) and if open issues remain, come back with more clear questions.
    For the time being I'll close this thread.
Thread Status:
