ok, so i need to control the flow rate coming out of a water pump, to do this i decided to use a variac, my question is, if the pump is rated at 0.7A, can i use a 2.5A variac with it? (it will go in the order, power supply, variac, water pump) I thought i could because its the pump that draws the current, but im not sure and i need to know quickly.
Categories
Platforms
Content
