K
Kevin Aylward
John said:On Tue, 11 Jan 2005 19:57:25 GMT, "Kevin Aylward"
The rest of what you say here, is even more amazing.
Granted, but what you said you wanted to talk about wasn't the concept
of transconductance, it was that the "actual physics" of a BJT made it
a transconductance device. That being the case, what's nonsensical is
that almost anything can be called a transconductance device, so just
calling a BJT a transconductance device doesn't really say anything
about the physics behind it. Consider a simple potentiometer on the
bridge of a ship which is used to control the ship's speed. Is what's
being used to turn the screw a transconductance device? Sure. Does
it tell us anything about what's between the pot and the screw? No.
Same thing with a BJT. But dig a little deeper and we find that all
the voltage across the base-emitter diode is doing is pumping charge
through the diode,
No. Vbe is setting an *electric field* that attempts to accelerate
charges from the emitter into the base region. This is truly 101
physics.
that _current_ being what causes the collector
current to flow.
NO! NO! NO!. Absolutly not. You are wrong. It is not the flow of charge
in the base that *causes* collecter current. This has already been
explained in many posts.
Charge flows because of:
F=q(E+vxB)
That is, excluding magnetic effects, it is *Electric Fields* that make
chages move. Period. The flow of charge, excluding magnetic effects,
cannot make other charge flow, other then by the change in electric
field that such flow might cause.
For the umpteenth time. Applying an *electric field* to the base emitter
injects carriers from the emitter into the base region. Once the
carriers are in the base region, they are attracted by the *electric
field* of the collector and are swept up (collected) by the collector
due to this *electric field*. Some of the emitter carriers just don't
make it, and are picked up via the base terminal. This base current is
an *effect* not a cause, and is incidental to the base emitter *electric
field* injecting carriers.
To repeat, it is not the *motion* of base charge that *causes* the
*motion* of collector/emitter charge. It is the electric field at Vbe
that causes both base current and collector/emitter current, as it is,
now get this 101 physics, *ELECTRIC FIELDS THAT MAKE CHARGES MOVE*. End
of story. Period.
I have already given a link that diagrams this behaviour.
http://www.st-andrews.ac.uk/~www_pa/Scots_Guide/info/comp/active/BiPolar/page2.html
If that's true, then a BJT isn't a transconductance device because the
collector current isn't a _direct_ consequence of the base-emitter
voltage, it's once removed since the _direct_ consequence of the
base-emitter voltage is the base-emitter current.
No. This shows that base current is an effect, of an electric field
cause.
I am still amazed that after all these posts, you still don't understand
the basic operation of the bipolar transistor.
F=q(E+vxB)
Its that simple.
See above.
No, it isn't.
What I'm claiming is that when there is no charge being injected into
the base region, the NPN sandwich is as clearly delineated as
bread-ham-bread would be. BUT, (and it's a BIG but) when charge
starts being injected into the base region the ham starts to look more
and more like bread as more and more charged is pumped into it, with
the eventual result being that the ham looks and acts enough like
bread to take on the characteristics of bread. So, if the P type
material in the base gets enough electrons pumped into it to make it
look like N type material, then the battery connected from the
collector to the emitter will start seeing less and less resistance as
the base current gets larger and larger and will cause the collector
current to increase as the base-to-emitter voltage (and the base
current)increases.
And this is all wrong. I have already explained, a continuous resistance
would mean that the base is connected to that resistance, hence, no
transister action.
Quite frankly, as noted above, you simply don't understand how a bipolar
transistor works. Read and understand the above. Its the way it is. I
can tell you that if you gave this description in an academic
semiconductor physics class, you would get a zero grade.
For some reason, you have picked up an erroneous understanding of
transistor operation. You need to get to grips with the idea that you
have been mistaken on this issue. This isn't debatable. Its in all the
academic text books.
Look, actually produce a detailed *physics* explanation as to *how* a
flow of base charge can actually induce a flow of collector charge. This
should tell you something.
In all the semiconductor text books I have read, I have never seen this
done, so why you can claim that this is the case, is pretty far fetched
indeed.
And this is wrong.
Which isn't the case here. The error due to rbb' is usually small. It
doesn't change the bipolar from its fundamental physics description as a
voltage controlled device. Rbb' just makes the calculation of the
voltage a little more involved.
And yet in your last post it was:
..."this base current is simply a nuisance."
There is no conflict here.
Kevin Aylward
[email protected]
http://www.anasoft.co.uk
