Difference between a DLL and a PLL
Discussion in 'Electronic Design' started by bender, Jan 12, 2006.
  1. bender
    bender Guest
    What is the general difference between a DLL and a PLL?
    Which is better for a high speed, low jitter design?
  2. bender wrote...
    When I think of DLL, I think of Microsoft's #%^&^. When
    I think of PLL, I think of the fine Philip's IC offerings.
  3. Donald
    Donald Guest
    DLL = Dynamic Link Library
    PLL = Phase Locked Loop
    Context would help !!
    donald
  4. John  Larkin
    John Larkin Guest
    DLL = delay-locked loop. A time-difference comparator servoes a
    variable-delay element.
    PLL = phase-locked loop. A frequency/phase comparator servoes a
    voltage-controlled oscillator.
    Definitions are subject to flames.
    Neither has an inherent jitter advantage, although a pll can have less
    output jitter than it has input jitter, and a dll usually can't.
    John
  5. bender
    bender Guest
    I did mean delay locked loop and phase locked loop.
    Thanks john.
    I am a little confused by the nomenclature but cant a variable-delay
    element be considered as an oscillator.
  6. Tim Wescott
    Tim Wescott Guest
    Not in a DLL. A DLL just takes the incoming signal and delays it by a
    variable, feed-backable amount.
    A variable delay element can be used to _make_ an oscillator, but you
    need an amplifying element to go along with it.
  7. Jim Thompson
    Jim Thompson Guest
    DLL, Delay Locked Loop, used to edge-synchronize clock distribution in
    a fast multi-chip system.
    PLL, Phase Locked Loop, usually used to generate multiples of a
    reference frequency, however analog PLL's can be used to recover
    signals buried in noise.
    ...Jim Thompson
