billymc: Here's the diagram that wouldn't display correctly on the fieldlines discussion board: Batt+ | | +--------------+------------------------+---, | | | | | | relay ) - / / coil ) ^ 1N400X \ \ ) | / / ,--/\/\/\--, +---' \ \ | | | / | | |\ | |D \ <--/\/\/\/\-------+---|+\ | |-- / | | >---+-----|| n-channel \ +--------|-/ |-- mosfet / | |/ |S | | | | / gnd gnd /_ 5.6 v zener | gnd Use the contacts of the relay (not shown) to connect the battery to a dump load. This way you won't have any heating of transistors and such. Note that hysteresis (the feedback resistor to the op-amp pos input) is necessary with this circuit to prevent chattering of the relay. The dump load will turn on at a certain voltage and hold on until the battery drops to a certain lower voltage, determined by the values of the resistors on the input of the op-amp. You can look up op-amp hysteresis or similar terms in Google, and you will find the formula to calculate resistor values that will give you the exact voltage window you want.
