R
Robert Monsen
Trudeau said:On the following link it says in part the following....
Most diacs are used for pulse generation, probably in the order of amps, and
are designed as such. I think the published ratings for static (DC) use are
a bit on the consevative side, take a 1N4148 sized diac and say 100 to 200
mW dissipation and about 2V across the diac we are left with 50 to 100 mA,
more than enough!
http://www.hut.fi/Misc/Electronics/circuits/tele_privacy.html
My question is, Is this web site confused. When I looking up a 1N4148 it is
NOT a Diac, it is a Diode. Please bear with me as I'm a novice. A Diac goes
in one direction and will start conducting electricity at a certain voltage.
I Get that.
A diode works in one direction also but from that point I'm a little unsure
what the difference is. Can anyone explain this in simple terms? Does the
Diode also limt voltage eg. a 5v Diode limits voltage to well .. 5V.
Regards
A 1N4148 is a diode. A diac is not a diode.
http://www.americanmicrosemi.com/tutorials/diac.htm
Regards,
Robert Monsen
"Your Highness, I have no need of this hypothesis."
- Pierre Laplace (1749-1827), to Napoleon,
on why his works on celestial mechanics make no mention of God.
