electronicsLearner77
- Jul 2, 2015
- 306
- Joined
- Jul 2, 2015
- Messages
- 306
What is E2? Why would you use an RMS value + angle here? Makes no sense. Use the vectors as given in the task description.What is the mistake?
Not directly. You can paste an image of a set of equations generated by LaTeX.can I use latex here?
No. What you show here is e2, but for E2 you use the RMS. Why? That's not correctI am not sure if this is what you are asking. I have represented in phasor notation for E2
Up to this part everything is correct.e1 + e2 = v -> Applying the Kirchoff's Voltage Law
e1 = v - e2;
I don't want to drag it further, but my point is here we are dealing signals and our topic is electronics and not trigonometry. So solving like a trigonometry problem you miss the signal analysis. This is only my point of view.
O.K..Generally all AC circuit analysis is done using phasor notation. Am I correct?
For a very few savvy ones like you: yes. LaTex isn't that common. You can always post an equation created in the favorite tool of your choice (there are others than LaTex, more specialized in primarily typesetting math equations) as an image, as you obviously have done.Note: It would really help if you upgrade to Latex editor.
This is really a good point. Thank you. I was breaking my head if i have to add or subtract.It doesn't matter which ot the two you chose because you'll end with either 160.23 ° or -99,77 ° which is the same
