C
Chris Carlen
Hi:
For a few different categories of interconnection from a PCB containing
inputs and outputs, how much protection from ESD, overvoltage, and
electrical surge should be applied?
Here are my standards:
1. BNC or other physical connection logic/analog signal input from the
external world on something that warrants being called an "instrument"
(not some development board on my bench, but a final product that needs
to impress a customer). This connection will be frequently connected
and disconnected, and is likely to have bare wire adapters attached by
the ordinary user while taking no ESD precautions.
This should have the maximum protection. Inputs should have a resistor
sized for acceptable balance between input bandwidth and current
limiting during ESD events and overvoltage application, dual diodes to
the rails for primary ESD shunting away from the device, and another
resistor between that diode and the device. The power rails need shunt
protection from slower transients via a TVS and DC overvoltage
protection via a zener or SCR crowbar.
Input network should be modeled with an RLC pulse source with component
values and initial voltage conforming to the IEC 1000-4-2 ESD models,
and verified that the protection and protected devices do not have their
ratings exceeded. Actual testing should be performed as well.
2. Multi-pin connectors such as D-sub and others that are intended to
connect some other sensor or instrument to the "instrument", and that
will not be changed frequently.
This one's a little more difficult. It might be very costly and take a
lot of board area to put the full suite of protections on every pin in
this case.
What I commonly see for these situations, is a single RC network. I
wonder if the designers of these RC networks are certain that they can
actually protect against standard ESD models? In my recollection from
my recent SPICE experiments with ESD protection networks, RC networks
just tended to shuffle charge from the external capacitor to the
internal one, and causing the (presumed) protection diodes in the device
to be protected to bear an excessively large surge current.
Thus, this protection usually can't meet the tougher 8kV and 15kV
contact and HBM ESD models. In fact, I am not certain it is really
intended to protect against ESD at all, but rather intended just to
provide some noise filtering.
So perhaps most designers forgo thorough ESD protection on these
multi-pin connectors, assuming that since they are not to be changed
frequently, that there is little change of ESD damage occurring here?
Is this a wise practice on robust instrumentation?
3. Connections from one board to another inside a chassis, assuming
that reasonable protections are in place on each of the boards.
Here I think it is acceptible to provide no protections.
4. Outputs from devices such as op-amps (analog) and logic chips (logic
levels).
I rarely see ESD protections applied to these. Though I have tended to
apply some protections to these as well. I have put SMD 0.2A fuses, to
a pair of diodes to the rails. Then a resistor between my diodes and
the device output pin. That way if there is an overvoltage applied, at
least just the fuse blows instead of the whole output device.
Your input is of interest.
Good day!
_______________________________________________________________________
Christopher R. Carlen
Principal Laser/Optical Technologist
Sandia National Laboratories CA USA
[email protected]
NOTE, delete texts: "RemoveThis" and "BOGUS" from email address to reply.
this case.
levels).
Good day!
[email protected]
