N
N_Cook
Is there an online calculator anywhere ? or failing that what sort of
"packing factor" for 0.08mm (+/- .005mm ) winding on a relay coil.
I have a good idea of the weight , subtracting an estimate of the plastic
former and this would give the length from the density of copper but number
ot turns ?.
Impregnated coil so cannot count-off turns
Rectangular section to coil , on the inside anyway, 14x 16.4mm , 16.8mm
width, outer layer is curved at "corners" and bulging (from the winding not
abuse) so more scatterwound than precise regular lay-up .
Outer dimensions of 21.4mm bulge / 20.3mm , or so, at outer edges one way
and 23.4/22.2mm , the other, a bit of geometry would give a good idea of the
volume of this space but what ratio of that volume would be copper and what
air+varnish, then what sort of weight would be contributed by the varnish?
ot turns ?.
