Hello all,
I'm trying to figure out how to choose DC adapters. I understand I have to consider all the elements like, Current, Voltage and power.
I've seen many adapter spec's drawings, but they're confusing.
I have a couple of Color Car Reverse Cameras. One 9 volts, and one 12 Volts. I've seen a person use a 9 volt battery with his instead of hooking up to the Reverse Backup lights.
I'd like to use these same cameras in other applications with either a 9 volt battery or a DC Adapter. How do you determine which one to get? Also want to use the 9 volt with the 12 volt Color Car Reverse Camera. The threshold is 9 to 12 volts. So either a battery or DC adapter should work.
Will you point me in the right direction?
Do I just check the spec's for Voltage and Current? Some Adapters have weird symbols, and even though they same specs the look different: ----Co----- or other direction. The O should be inside the C, but didn't see a drawing package here or able to attach photo.
I attempted to attach a picture. Don't know if it did or not. Can't see it.
