determining current use of circuit
Discussion in 'Electronic Basics' started by tempus fugit, May 2, 2004.
  1. tempus fugit
    tempus fugit Guest
    Hey all;
    This something I've wondered about for some time now. If I want to check the
    DC current consumption of a circuit powered by, say, +15v, all I need do is
    insert an ammeter in series with the circuit. Easy enough. How do I
    determine what the consumption of a dual supply circuit is though (i.e.,
    +/-15v)? Do I insert the ammeter at a positive point in the circuit and at
    a - point in the circuit and add the 2? Or can I just insert an AC ammeter
    in between the xformer 2ndary and the rectifier circuit?
    On that subject, If I have a xformer rated at 200mA, I assume that is an AC
    current rating. Will measuring the AC current draw (by inserting the ammeter
    before the rectifier circuit) give me the total current load on the xformer,
    or do I need to include the DC current as well?
  2. Consider a circuit with +15, 0, and -15 rails. Depending on the load between
    the rails, the current will take different paths. For example, if you have a
    15 ohm load between +15 and 0, and no load between the 0 and -15 rails, then
    the current will travel out of the +15 terminal of your PS, back into the 0
    terminal.
    If, on the other hand, you now add a 15 ohm load between the 0 and -15 rail,
    then the current will now travel out of the +15 back into the -15, and no
    current will pass through the 0 terminal.
    Thus, the total DC current is really the maximum of the 15 to 0 and the 0
    to -15 current, not the sum.
    Regards,
    Bob Monsen
  3. tempus fugit
    tempus fugit Guest
    Thanks Bob.
    OK..... so how do I measure that?
  4. Jamie
    Jamie Guest
    sine you have 2 sept. outputs on your power supply it should be the
    combined current.
  5. CFoley1064
    CFoley1064 Guest
    Subject: determining current use of circuit
    True -- except the voltage burden of the ammeter may change the current draw.
    Circuits are specified for current draw on the + and the - separately. When
    choosing a power supply for your application, choose one with a current
    capability that's more than the greater of the two. For instance, if your
    circuit uses 0.85A @ +15V and 0.01A at -15V, get a +/-15V power supply rated at
    more than 0.85A.
    If you're using a full-wave rectifier circuit like this (view in fixed font or
    M$ Notepad):
    Full Wave Rectifier Power Supply ____
    .-----o-----|78XX|----o-----o+
    .-------. | | |____| |
    -. ,-------o~ +o--' --- | ---
    ) ,---. | | o-------o-------o-----oGND
    )|( GND | | --- | ---
    -' '-------o~ -o--. --- _|__ ---
    '-------' '-----o-----|79XX|----o-----o -
    |____|
    Buy a transformer with an AC current rating 1.8 times the larger of the two DC
    current outputs.
    Good luck
    Chris
