detecting a red pocket on roulette wheel
Discussion in 'General Electronics' started by Quack, Jan 23, 2004.
  1. Quack
    Quack Guest
    I have an interesting task here - i want to sit something on the rim
    of a roulette wheel, and get a +5v logic signal while the red pocket
    is infront of this 'something', and 0v (or close to it) while its not.
    The problem is the lighting conditions are indoors, and shadows may be
    cast, so i want it to automatically calibrate somehow to these
    effects.
    The wheel also has a green pocket, which i dont want to triger.
    I have a selection of photodiodes i purchased for experimentation -
    and im considering how to go about this.
    I could use an A2D, like a PIC16f877, it has an internal A2D, but i
    think its too slow. My tests show that i can only get a reading every
    10ms, i need a lot more than that.
    So this is why i would like to make an analogue circuit that would be
    'biased' to logic levels, for a simple '1' or '0' depending. But then
    the lighting conditions come into play ... also the green may trigger
    it.
    Im really not sure how to do it.
    what if i was to have a red led, and a suitable 'visible light'
    photodiode, and take a reading with the led off, then with the led on
    (over and over again) and use the difference to workout if its right.
    OR compare readings to a 2nd photodiode which is unaffected by the led
    output. or something like that - but the problem with that is it needs
    A2D, and thats too slow.
    The wheel has 37 pockets, and spins at about 2 1/2 seconds per
    rotation, leaving me about 15 pockets per second to check - but its
    not enough to get '1 pocket per reading', i need a much higher
    resolution than that.
    Im not sure im explaining it right, but how would any of you go about
    setting something like this up ?
    Any suggestions would be great!
    Alex.
  2. Tim Dicus
    Tim Dicus Guest
    Hi Alex,
    That is an interesting project! Planning on making some money? Can I get in
    on it if you are? :^)
    Depending on how close you can get the device to the wheel, you may want to
    try a reflective transmitter/receiver device like you suggested. Use a red
    (or IR if you want to be stealthy) focused laser diode as the transmitter.
    Aim it at the pocket. Use a focused photodiode to pick up the reflected
    light. Red pockets should reflect much more of the laser diode light than
    the green or black pockets.
    You may want to consider using a pulsed output on the laser diode (say
    40KHz) and a PLL device (LMC568 would be my choice) on the photodetector.
    This will help eliminate some of the ambient light challenge you may have.
    It may require some manual or automatic calibration to operate correctly.
    It seems that an A/D conversion every 10ms (100 conversions/second) would be
    fast enough. That would be more than 6 conversions per pocket.
    Does that make sense?
    Tim
  3. Garrett Mace
    Garrett Mace Guest
    Figure out which color reflects more light; possibly put a red filter over
    the detectors to increase the difference. Now place *two* detectors such
    that when one detector is reading a green pocket, the other is reading a red
    pocket. Now, when you read the two values, you know that the one with the
    higher value is going to be the red one. So you compare the values and pick
    the higher (perhaps looking for some amount of separation) and the result
    should be much more independent of the ambient light.
  4. ~^Johnny^~
    ~^Johnny^~ Guest
    Russian technology, perhaps? ;->
  5. Quack
    Quack Guest
    Hi Alex,
    Its actually a legitimate project :).
    Its for a results reader/logger.
    They do exist already, TCS and Huxley make them, but not to the
    specifications we need for this.
    Yes very close, within about 10cm of the ball, 5-10cm to the pocket
    (Depending on where we point it) - sitting ontop of the rim, slightly
    overhanging. Nice and close is fine.
    Actually what im using now are two "Balluff laser contrast scanners" -
    which i have configured to recognise the red from the other pockets -
    these give a pnp output and i use it pretty much directly in my logic.
    (PICmcu controlled)
    I am also using a SICK proximity switch to detect the ball.
    By using two of the above balluff sensors, i can tell the direction of
    the wheel pretty much instantly, due to the order in which they 'rise'
    or 'fall' (they are pointed next to each other on the wheel).
    And by doing some tricky timing i know when the green went past, and
    therefore when the above mentioned SICK sensor triggers from the ball,
    i know which pokcet its in. (i start an incrementing pocket count from
    zero - and then when the ball is found, do a lookup table depending on
    the wheel direction to find the result)
    So as far as logic goes, i have it all down - working great.
    Due to the Balluff sensors using a focused laser diode, reading a
    'spot' of color - it must be alligned VERY accurately so as not to see
    any 'text' - just the colors. It just so happens that there is a
    narrow band of pure color just above the text on roulette wheels, and
    this is a great detection spot - but is very narrow, and a good bump
    puts things out of allignment :(.
    The prototype is actually running in a real casino now - sometimes
    weeks without a problem, but then one day the cleaners will touch it..
    and i get phone calls.
    But that is a prototype - and using pre-packaged sensors is not only
    expensive, its very difficult to customise a nice enclosure.
    So im thinking of something with a more 'diffuse' nature, so it wont
    be so picky about 'precise' positioning.
    So before i can go and design a more solid enclosure for the next
    version, i want try out some more designs.
    I will post some pictures up here today to make things clearer ...
    Really i am hopeless with all things analogue - and i find it
    painstakingly tedious to try and get things like this working :(. I
    really appreciate all help.
    Alex.
  6. Quack
    Quack Guest
    Some pictures to clear things up;
    the wheel pockets, and current laser positions;
    www.quack.cc/wheel_numbers.JPG
    balluff sensor
    www.quack.cc/balluff_sensor.JPG
    sick proxmimity switch
    www.quack.cc/sick_sensor.JPG
    So what im trying to do is remove the necesity to point at that 'spot'
    on the wheel - so a more diffuse, perhaps red led/photodiode approach,
    instead of focused laser. (as the accuracy of positioning is very hard
    to accomplish in the 'real world')
    But then this would leave me the wheel direction problem.
    Ahh, but if i could detect green independently, then the wheel
    direction problem is solved, as on one side of the green its a red
    pocket, and the other a black. So by merely asking 'which pocket came
    after green' answers the direction of the wheel.
    So i also need a seperate circuit to detect green too, as its own
    trigger - seperate from red completely.
    And then these must work with each other - reading the same pocket at
    the same time (or close to it). So as not to interfere with each
    other.
    I could just spend some time trying to design an enclosure which would
    hold the above balluff sensors in a very tight formation - but i think
    no matter what, its going to be very common for this thing to get
    moved.
    Alex.
